power moonroof problems
Old May 22, 2004 | 07:21 AM
jdmrex91's Avatar
Default power moonroof problems
does ne one kno why one of the tracks for the moonroof might stick up for a 91 rex si....i've tried numerous things oil everything when taken apart put back to gether and still no luck....am i better off jus gettin a whole moonroof assembly and ripping the junkone i have out???.....help me out guys.......thankx
Old May 23, 2004 | 09:58 AM
jdmrex91's Avatar
Default Re: power moonroof problems (jdmrex91)
come on someone help me out im lost............
Old May 23, 2004 | 10:38 AM
spyz34's Avatar
so does it open and close all the way, get stuck, what?
Old May 23, 2004 | 11:35 AM
jdmrex91's Avatar
Default Re: power moonroof problems (spyz34)
it opens and closes but the pass. side track wont fold down into the seat or tray whatever u want to call it so the pass side always sticks up.....but it closes as far down as possible before the track wont fold ne more...so the driver side is all the way in and the pass side is kinds stickin up in the air.....
Old May 23, 2004 | 12:18 PM
regime's Avatar
there are 4 lil plastic stoppers (2 on each side) that tend to break alot. when you had it apart did you notice if they were all together. if its stayin up on the passenger side the front passenger side stopper sounds busted..
gl
Old May 24, 2004 | 04:52 AM
jdmrex91's Avatar
Default Re: power moonroof problems (regime)
nope the plastic stopper are fine....its the metal rail that the moonroof slides on that is stayin up......im not even sure what its called but the metal tracks slide out of it when the moon roof slides back and when closed they slide into it and then it should all fold down and in the driver's side does but passenger doesnt.....
thinkin about takin to my local honda dealer and asking about it cause i am completely lost on why this wont work
Old May 24, 2004 | 05:01 AM
Lil Red CRXsi's Avatar
Did you make sure there is no trash or anything in the pass side track?
Old May 24, 2004 | 07:17 AM
spyz34's Avatar
Default Re: power moonroof problems (Lil Red CRXsi)
hey do u know how i can change the stoppers because mine are broken and i cant open my roof more than half. Is there a way to take the whole setup off including rails?
Old May 26, 2004 | 04:04 PM
regime's Avatar
if the rails are sliding out of the panel then i still say its the front stoppers. but you can look at it and see that its not so i guess i dont know
to change them just take the unit out and take the panel off and you have access to them all. good time to clean and put some light oil on it as well
Tower
Feb 21, 2012 05:56 AM
tercelrcr
Dec 3, 2010 06:23 PM
BlUeDC2nEr
Acura TSX
Jun 11, 2007 08:11 PM
TheBobFather
Oct 23, 2005 08:43 PM
migs
Jul 6, 2003 11:54 AM
