How much of a problem is it to do forced induction with a Mini-me?
Old May 22, 2004 | 06:55 AM
onemanlan's Avatar
Default How much of a problem is it to do forced induction with a Mini-me?
I read on a CRX page about the Mini-me, which I'm interested in, but I was wondering... How much of a problem is it to put forced induction with a Mini-me engine? Because it said the compression ratio goes up a point or two and I want to avoid detonation at all cost.
And a few more questions about detonation and prevention.
Doesn't higher octaine fule take the compression ratio down a bit?
What about other parts that would lower the compression ratio?
Old May 22, 2004 | 09:08 AM
91civicDXdude's Avatar
im boosting 10psi daily on a d16y7 block with a d16z6 head.
It all depends on what block you use. the y7 block will actually have about the same compression as a stock d16z6, but if you use an a6 block or a 1.5 block, you will have higher compression.
Old May 22, 2004 | 10:04 AM
onemanlan's Avatar
Default Re: (91civicDXdude)
I was thinking the a6 block with changed out heads. I heard the stock a6 engine ran 9.1:1 compression ratio and the swap boost it up to 10:1, if not low 11:1 CR. Boost ads more compression, so I was wondering how much of a problem is it to run boost with the CR that high.
Old May 22, 2004 | 10:41 AM
TIRENECK's Avatar
Default Re: (onemanlan)
thats with a thicker HG or without?
Old May 24, 2004 | 12:39 PM
slofuckncrx's Avatar
Default Re: (TIRENECK)
Just use a Mr. Gasket MLS Stackable Head Gasket.
Old May 24, 2004 | 03:15 PM
-16V-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">im boosting 10psi daily on a d16y7 block with a d16z6 head.
It all depends on what block you use. the y7 block will actually have about the same compression as a stock d16z6, but if you use an a6 block or a 1.5 block, you will have higher compression.</TD></TR></TABLE>
A 91civicdxdude, how is that new turbo setup going???
How does it feel now, compared to stock????
Have u messed with any "newer" cars on the road yet???
Old May 24, 2004 | 06:05 PM
ExplicitSpeed's Avatar
Default Re: How much of a problem is it to do forced induction with a Mini-me? (onemanlan)
http://www.homemadeturbo.com
Old May 24, 2004 | 06:50 PM
onemanlan's Avatar
Default Re: How much of a problem is it to do forced induction with a Mini-me? (ExplicitSpeed)
Sweet site dude. Thanks
DeadVet
Apr 26, 2005 11:51 AM
DeadVet
Mar 30, 2005 04:37 PM
DeadVet
Feb 9, 2005 12:34 PM
dumbkid
Aug 17, 2004 11:21 PM
