new setup- 56knono
Old May 22, 2004 | 05:37 AM
DD_JonnyLee's Avatar
Default new setup- 56knono resized pics
-jonny
Modified by Raped-Ape at 2:18 PM 6/5/2004
Modified by Raped-Ape at 2:19 PM 6/5/2004
Old May 22, 2004 | 05:38 AM
Default Re: new setup- 56knono (Raped-Ape)
and yes thats a 1st gen dsm bov, someone stole my other one from a friends house
Old May 22, 2004 | 06:05 AM
B18C1CYA's Avatar
what turbo mani is that? looks good
Old May 22, 2004 | 06:24 AM
G
sh!t happens.
Default Re: new setup- 56knono (B18C1CYA)
bump for yea... keep this setup together johnatan.... best one yet
Old May 22, 2004 | 06:28 AM
Rod.'s Avatar
nice setup
Old May 22, 2004 | 06:59 AM
SOHC_MShue's Avatar
nothing wrong with the 1g bov
Old May 22, 2004 | 09:41 AM
ATS*Mark's Avatar
OG triple OG
Default Re: new setup- 56knono (HybridHatch88)
so how come people always make these "new setup" posts , and dont actually say what the setup is?
it "looks" good man but tell us whats in it
RobbieG35's Avatar
12 Years Strong
Default Re: new setup- 56knono (SOHC_MShue)
This thing is a beast, I hope to be as fast one day
Old May 22, 2004 | 10:25 AM
94gsr4dr's Avatar
looks good, 1G BOV is no slotch, its as good if not better than some aftermarket BOV's
Old May 22, 2004 | 11:57 AM
G
sh!t happens.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHatch88 &raquo;</TD></TR><TR><TD CLASS="quote">This thing is a beast, I hope to be as fast one day</TD></TR></TABLE>
you just said that robby.. double post? j/k
Modified by G"UNIT at 2:00 PM 5/22/2004
Old May 25, 2004 | 10:38 PM
Default Re: new setup- 56knono (G"UNIT)
head:
crower valvesprings
crower retainers
ferrea s/s 1mm oversized valves
block:
endyne wiseco's 81.5mm 9:1
endyne eagles
hondata 4b
siemen 880cc injectors
3bar map
stainless equal length mani w/jethot coating
3in dp jet hotted
sc61e
tial 40mm
revhard chargepipes
dsm 1st gen bov
clutchnet stg 4 clutch
JG intake mani
thats all i can think of now, i know im forgetting some stuff
oh yeah, on the old HP sheetmetal intake and inline pro mani, i made 317@10 lbs
it needs to be retuned, but it feels like it has alot more midrange now
Old May 25, 2004 | 10:45 PM
Blackack26's Avatar
Was the mani jet-hot coated? Looks good
And yeah the DSM bov is great, I'm using the same one in my setup.
Old May 26, 2004 | 02:11 AM
Charles B.'s Avatar
Default Re: new setup- 56knono (Blackack26)
looks good. any more pics? wht kinda of intercooler?
Old May 26, 2004 | 03:19 AM
RobbieG35's Avatar
12 Years Strong
Default Re: new setup- 56knono (CharlesInTurbocharge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CharlesInTurbocharge &raquo;</TD></TR><TR><TD CLASS="quote">looks good. any more pics? wht kinda of intercooler?</TD></TR></TABLE>
Its a Spearco, but im not sure of the dimensions. Probabley the size if a Precision 1026
Old May 26, 2004 | 05:14 AM
Casey's Avatar
nice...so its stock sleeved? how much boost do you plan on running with race gas? i should have a similar setup(compression and turbo will be close)
Old May 26, 2004 | 07:53 AM
T3-T4TEG's Avatar
the 1g dsm bov is cool, thats what I'm using on my ls turbo setup. I've heard they are good for 30psi, which I'll never run even close to.
Old May 26, 2004 | 07:56 AM
RobbieG35's Avatar
12 Years Strong
Default Re: new setup- 56knono (Casey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey &raquo;</TD></TR><TR><TD CLASS="quote">nice...so its stock sleeved? how much boost do you plan on running with race gas? i should have a similar setup(compression and turbo will be close) </TD></TR></TABLE>
Yes stock sleeves. With the old set-up Hondata tuned he ran up to 14 on pump gas.
Never ran on race gas. This set-up has went 7.7 @ 91mph in the 1/8 mile on 23s
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T3-T4TEG &raquo;</TD></TR><TR><TD CLASS="quote">the 1g dsm bov is cool, thats what I'm using on my ls turbo setup. I've heard they are good for 30psi, which I'll never run even close to.</TD></TR></TABLE>
Actually this one isn't crushed and leaks at like 13 pounds Sounds good though
Old May 26, 2004 | 08:10 AM
T3-T4TEG's Avatar
yeah your right, I forgot you have to crush the top for it to hold more psi
Old May 26, 2004 | 09:21 AM
actually, ive never ran more than 12.9lbs because of the boost cut on hondata, but the good ole crapometer boost gauge indicated 14lbs
Old May 26, 2004 | 11:06 AM
Casey's Avatar
what was your whp on 12.9lbs with pump? 317 at 10 is more than i was hoping for at 12-13 which i think is safe for what im going with(9.3:1, its sc61/gt35 killer) and 20 or so on race gas
Old May 26, 2004 | 09:37 PM
never tuned on that much, when i had it tuned at balanced performance Ed didnt want to make more than 300whp on the stock sleeves, so on the first full pull it was on ten(wastegate setting) so he just tuned it there and put the boost cut at 13lbs
-jonny
Old May 27, 2004 | 03:22 AM
RobbieG35's Avatar
12 Years Strong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey &raquo;</TD></TR><TR><TD CLASS="quote">what was your whp on 12.9lbs with pump?</TD></TR></TABLE>
Enough to outrun our friends LS1 TA on the was back from the track. The Trans Am went 7.2 that day. From a low roll he got eaten alive on the spray Needless to say it flew in 12.9
Old May 27, 2004 | 07:44 AM
LordJax's Avatar
Very clean setup, looks great.
Old May 27, 2004 | 09:38 AM
Enough to outrun our friends LS1 TA on the was back from the track. The Trans Am went 7.2 that day. From a low roll he got eaten alive on the spray Needless to say it flew in 12.9</TD></TR></TABLE>
the trans am went 7.28@98 , ive never run him any lower than 50...i know better, but yeah on the way home i put a couple of car lengths on him
GRPNHRD
May 15, 2007 01:13 PM
REMUS 13
Welding / Fabrication
May 17, 2006 09:25 AM
Juan Q...
Jan 23, 2004 01:42 PM
