Is THIS an acceptable way to add wires to the ECU connector?
Old May 22, 2004 | 03:45 AM
EE_Chris's Avatar
Default Is THIS an acceptable way to add wires to the ECU connector?
Larger pic
As titled: Is this acceptable to you?
Old May 22, 2004 | 06:37 AM
al3e's Avatar
Default Re: Is THIS an acceptable way to add wires to the ECU connector? (EE_Chris)
donno, looks fine..? i donno bump cause i need to know also....
Old May 22, 2004 | 06:54 AM
Dyzee's Avatar
IMO as long as it dosnt touch any other connectors then your fine. I had the same thing in my car for a very long time and never had any problem.
Old May 22, 2004 | 07:57 AM
Civiclx's Avatar
it works but not as reliable as pins, if you need obd2 pins let me know i have some
Old May 22, 2004 | 09:03 AM
BatuKing's Avatar
Default Re: Is THIS an acceptable way to add wires to the ECU connector? (Civiclx)
HELL no that is soo not reliable or acceptable.. you can purchase the wires with the pins that go in there from honda. re=do it the RIGHT way
EF203
Dec 27, 2015 03:39 AM
sneakernoob
May 17, 2007 04:28 PM
untitled
Sep 14, 2003 07:25 PM
