overheating problems... any suggestions?
Old 05-20-2004, 12:27 AM
garagemidnight's Avatar
Default overheating problems... any suggestions?
Here's the situation... I have a B16 gen1 in a 94 cx. Running a 'teg LS harness to the B16 ECU. Vtec is not hooked up yet... The problem is, when the engine is started, no coolant is running in or out of the motor. Is there a way i can diagnois this problem? Could it be the Vtec not being hooked up?.... heard about that a while ago, something like Vtec somewhat controls part of the cooling of the engine. I need your help guys, I'm at a standstill, don't know what the problem is. Last resort would just be replacing parts..... Thanks in advance for the advice/help.
Old 05-20-2004, 01:24 AM
mikehawkBUiLT's Avatar
try your thermostat, its like a valve, when the coolant gets to the right temperature, your thermostat will open up, and coolant will run through your engine.
Old 05-20-2004, 04:37 AM
Kista20's Avatar
Default Re: (EJcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJcoupe &raquo;</TD></TR><TR><TD CLASS="quote">try your thermostat, its like a valve, when the coolant gets to the right temperature, your thermostat will open up, and coolant will run through your engine.</TD></TR></TABLE>
it's most def. your thermostat. BTW don't be cheap, get a honda one. They are much better.
Old 05-20-2004, 04:40 AM
JimmyAtlantis's Avatar
Default Re: (Kista20)
Possibly your thermostat. Are you leaking at all. Water pump?
Old 05-20-2004, 07:47 AM
suspendedHatch's Avatar
Default Re: (JRI94)
VTEC has absolutely nothing to do with it. Whoever told you that, probably drives a mustang. Kick them.
Old 05-20-2004, 08:22 AM
Mike_C's Avatar
you may have a bad water pump too.
Old 05-20-2004, 09:26 AM
yaya's Avatar
Default Re: overheating problems... any suggestions? (garagemidnight)
when your first start it, in my understanding, coolant shouldnt be running from the radiator to the block. it just circulates in the block until it warms . THEN your thermostat will open as needed.
oh and the part about VTEC.
on the jdm engines, instead of an oil pressure sensor to allow vtec, its done by a coolant temp sensor.
so the jdm engines have to warm up, rather than the usdm ones have to get oil pressure in order for vtec to kick in.
im not sure if its controlled though the ecu, or if its just a switch (jdm engines)
Old 05-22-2004, 01:30 AM
Thanks guys, appreciate the help... I've tried the thermostat already, and it still runs hot (past the middle marker on the gauge) after about a minute or so... Is there a way I could check the water pump to see if it's good or bad, before I have to remove everything and get it out of the motor??? Thanks again for the help guys... this is my first 'swap' by the waym, and any comments or tips would be a great help....
Old 05-22-2004, 04:22 AM
Mike_C's Avatar
you didn't change the water pump while the motor was out? that is something most people do...
Old 05-22-2004, 09:05 AM
BatuKing's Avatar
Default Re: (MichaelJComputer)
check the flow thru the radiator by using a raytech gun and see if you have a clogged radiator
Old 05-22-2004, 09:15 AM
Default Re: (BatuKing)
If the water pump was bad it would be dripping from the weep hole.
Make sure you hooked all the coolant hoses up right, and one isn't pinched or sucked closed.
blue89hatch
09-07-2008 05:55 AM
sweetb16
10-26-2004 05:16 PM
rdaggett
08-11-2004 12:48 PM
scoobyghost
06-01-2004 05:10 PM
SpoolinEK
08-12-2003 11:27 PM
Quick Reply: overheating problems... any suggestions?
