Need some info about a b16a1 swap into 92-95 hatch
Old May 22, 2004 | 02:48 AM
giff74's Avatar
Default Need some info about a b16a1 swap into 92-95 hatch
I have a b16a1 that I want to swap into a 92-95 hatch. What are the issues around obd? I know the engine is obd 0, are the cars from that series obd 1? The other thing I am wondering about are the motor mounts, will this engine bolt right in or will I need special motor mounts?
Any other info about his swap that would be "useful" that you want to pass along is much appreciated. As always thanks for the help.
Old May 22, 2004 | 04:49 AM
Eyes Only's Avatar
Default Re: Need some info about a b16a1 swap into 92-95 hatch (giff74)
Get some hasport bseries motor mounts and it drops right in
Old May 22, 2004 | 05:55 AM
92b16vx's Avatar
Default Re: Need some info about a b16a1 swap into 92-95 hatch (LiL Jon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LiL Jon &raquo;</TD></TR><TR><TD CLASS="quote">Get some hasport bseries motor mounts and it drops right in </TD></TR></TABLE>
Yea, it will drop right in, and then just sit there since you won't be able to hook it up.
The easiest way would be to get a hydraulic tranny, a complete OBD I intake manifold with all sensors, and injectors, and a OBD I vtec B series distributor.
If not, you need a cable to hydaulic conversion kit, and a butt load of wiring. IMO, sell the 1st gen, and just spare yourself, and get the 2nd gen. Not to mention in emission controlled areas it's an illegal swap.
Old May 22, 2004 | 01:03 PM
giff74's Avatar
Default Re: Need some info about a b16a1 swap into 92-95 hatch (92b16vx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16vx &raquo;</TD></TR><TR><TD CLASS="quote">
If not, you need a cable to hydaulic conversion kit, and a butt load of wiring. IMO, sell the 1st gen, and just spare yourself, and get the 2nd gen. Not to mention in emission controlled areas it's an illegal swap.</TD></TR></TABLE>
I didnt realize it was so extensive. I thought I could get away with motor mounts and perhaps a wiring conversion.
Guess not....
Old May 23, 2004 | 03:06 AM
giff74's Avatar
Anyone else have a take on this, as far as degree of difficulty?
Old May 23, 2004 | 06:37 PM
giff74's Avatar
So is it nearly pointless to put a b16a1 into an eg or ej? Considering the amount of work it would require.
1sickef9
May 5, 2009 06:58 PM
dem0nk1d
16
Jan 20, 2007 06:55 PM
NSfit
Sep 15, 2006 10:37 AM
blackmagichonda
Honda Civic (2001 - 2005)
10
Mar 28, 2006 03:14 PM
EGcivicBoy
17
Jan 16, 2004 12:10 PM
