B series final drive ratio swapping.....cable & hydraulic interchangeablility?
Old May 21, 2004 | 11:25 PM
91civicDXdude's Avatar
Default B series final drive ratio swapping.....cable & hydraulic interchangeablility?
I want to know if i can use the 98 spec ITR final drive in a cable b series transmission....
anybody have experience with this
**EDIT**
are cable and hydraulic b series gearsets interchangeable
/**EDIT**
Modified by 91civicDXdude at 5:55 PM 5/22/2004
Old May 22, 2004 | 06:51 AM
b16_madman's Avatar
Default Re: B series final drive ratio swapping.....cable & hydraulic interchangeablility? (91civicDXdude)
I don't know, do you want shorter gearing? I'd suppose so with the ITR stuff. I'd call up someone who makes the LSD's or somethin and see what they say.
Old May 22, 2004 | 08:54 AM
bump
for someone with an actual answer
Old May 22, 2004 | 01:30 PM
TTT
Old May 22, 2004 | 02:04 PM
importboi22's Avatar
i know the small shaft s1, j1 stuff is NOT interchangeable with the bigger 92+ hydro tranny stuff, but i know for a fact that you can take a 92-93 LS cable tranny and put all the hydro stuff in there and vice versa, BUT only the 92-93 CABLE trannies are interchangeable with the 92+ hydro B series stuff
Old May 22, 2004 | 02:12 PM
okay thanks.
I've heard that only the YS1 cable tranny is interchangeable.
Old May 22, 2004 | 02:15 PM
90civichbsi's Avatar
Default Re: (91civicDXdude)
i kinda had the same question but i was lookin at putting a S1 4.4 final drive into a 90-91 Ls cable tranny
Old May 22, 2004 | 04:57 PM
HamiltonRex's Avatar
Default Re: (90civichbsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichbsi &raquo;</TD></TR><TR><TD CLASS="quote">i kinda had the same question but i was lookin at putting a S1 4.4 final drive into a 90-91 Ls cable tranny</TD></TR></TABLE>
Yes.
-Eric
Old Jun 2, 2004 | 07:44 AM
MikeySpec's Avatar
Default Re: (HamiltonRex)
what parts are needed to do this?I want to change the final drive on my y1lsd...
Old Jun 2, 2004 | 07:54 AM
Default Re: (MikeySpec)
5th gear and counter gear.
I think your talking about taking a 90-91 LS tranny and putting the 5th from it into your y1 (jdm). In that case it will work. You just need whats stated above.
-Eric
Old Jun 2, 2004 | 08:02 AM
MikeySpec's Avatar
I was looking to swap out the final drive out of an s1 into this y1 lsd...is that possible?
Old Jun 2, 2004 | 09:31 AM
rsbad454's Avatar
92-93 cables YS1's (GSR-LS) you can swap 92+ hydraulic internals into them. 88-91 B series should be interchangable between themselves as well.
Old Jun 2, 2004 | 09:51 AM
MikeySpec's Avatar
Default Re: (rsbad454)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsbad454 &raquo;</TD></TR><TR><TD CLASS="quote">88-91 B series should be interchangable between themselves as well. </TD></TR></TABLE>
I would please like to know for definite.......im in a bind right now and it seems as this would be the best setup for what im doing. And im about to toss this motor in within a week or so. Anyone?
Old Jun 2, 2004 | 11:41 AM
rsbad454's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeySpec &raquo;</TD></TR><TR><TD CLASS="quote">
I would please like to know for definite.......im in a bind right now and it seems as this would be the best setup for what im doing. And im about to toss this motor in within a week or so. Anyone?</TD></TR></TABLE>
i got this info on the 88-91 JDM and 90-91 teg tranny info from someone on the Honda Swap board or this board. He confirmed it would work...
Old Jun 2, 2004 | 03:56 PM
Davep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">5th gear and counter gear.</TD></TR></TABLE>
That should be the ring gear and countershaft for the final drive.
Old Jun 2, 2004 | 06:35 PM
blaqman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsbad454 &raquo;</TD></TR><TR><TD CLASS="quote"> 88-91 B series should be interchangable between themselves as well. </TD></TR></TABLE>
I have a lil exp. w/ cable tranny problems when trying to swap out synchros. I bought 90-91 synchros 1-2 3-4 complete in an effort to have joey @ Spark racing swap them into my 88-91 tranny. It didn't work. Then I tried 92-93 synchros just for $hits and giggles....still didn't work. Long story short. The only worthwhile thing that is interchangeable between 90-93 usdm trannys and 88-91 jdm trannys is the LS 5th gear. This is merely fro my personal exp. If urs is different...please post.
brianpdex
Jan 12, 2011 05:07 PM
civickiller
Apr 7, 2006 03:15 AM
snowseeker
May 3, 2005 05:38 PM
PM-Performance
Jun 14, 2004 08:16 PM
