Bog on WOT. OBD0 ---> OBD1
Old May 21, 2004 | 11:19 PM
EG8R's Avatar
Default Bog on WOT. OBD0 ---> OBD1
Gas pedal to the floor and it bogs! Its done this since I switched to OBD1. Its quite annoying. It will go up to about 3500rpm then bog and won't go anymore. Seems like the engine pretty much shuts off. I have held it to see what is does.... Its drop to about 1000 rpm and just back to 3500 and so on.... If I hold it just above the floor its fine.... Theres an Auto X coming up soon and I want to get this fixed.
Anyone have this problem before? It's wonky. Thanx
Old May 21, 2004 | 11:21 PM
bossman032's Avatar
Default Re: Bog on WOT. OBD0 ---> OBD1 (skelly ed666)
looks like a code 9 problem what cel ur getting??
Old May 22, 2004 | 01:54 AM
CRXracer88's Avatar
check your tps wires . try switching the two outer ones. samthing was wrong with a friends and it fixed it.
Old May 22, 2004 | 02:00 AM
hahagasdcrx's Avatar
sounds like distributor wiring woes......i agree with code 9 cyp sensor
Old May 22, 2004 | 07:22 AM
EG8R's Avatar
Default Re: Bog on WOT. OBD0 ---> OBD1 (90crxzcgasd)
I have no codes. *scratches head* Maybe I can find another ditributor and try that.
And TPS is fine. I've checked voltage and its fine....
Thanx.
Old May 22, 2004 | 08:21 AM
bossman032's Avatar
umm did u switch the wires for the tps.
I thinks its different on the std civics and dx
Old May 22, 2004 | 08:40 AM
EG8R's Avatar
Default Re: Bog on WOT. OBD0 ---> OBD1 (bossman032)
Yes I did. I switched the two outter two TPS wires when I did the MPFI swap....
It ran fine on OBD0. My distributor crapped out on me then I switched to OBD1 because it was cheaper at the time.
Old May 24, 2004 | 05:41 PM
EG8R's Avatar
Well I got it fixed. Switched the 2 outter TPS wires.
What I don't understand is.... To go from DPFI to MPFI they have to be switched but then when going to OBD1 they have to be switched back... bleh Ah whatever it works lol
Thank you
Old May 25, 2004 | 09:02 PM
CRXracer88's Avatar
haha i told you....
efdxjdm
13
Sep 12, 2009 04:23 PM
chadmasterc
14
Nov 17, 2004 10:33 AM
ruby civic II
May 30, 2004 08:50 AM
91civicEX
15
Sep 3, 2003 10:33 PM
