Supra TT Fuel Pump Install Fuel Pump Priming Car not starting!!!
Old May 21, 2004 | 11:14 PM
bossman032's Avatar
Default Supra TT Fuel Pump Install Fuel Pump Priming Car not starting!!!
fixed if u have any question PM me.
Modified by bossman032 at 5:18 AM 6/2/2004
Old May 21, 2004 | 11:21 PM
bossman032's Avatar
Default Re: Supra TT Fuel Pump Install Fuel Pump Priming Car not starting!!! (bossman032)
TTT
Old May 22, 2004 | 04:30 AM
TiggsCRX's Avatar
give it a full tank of gas
i've heard of people using other fuel pumps that don't have pickups that reach like the last half of the tank...and since you only have 5 gallons in it, you only have half a tank
Old May 22, 2004 | 05:13 AM
deftones0817's Avatar
Default Re: (TiggsCRX)
why did you u use a crx/civic fuel pump?
DEF
Old May 22, 2004 | 07:31 AM
FourthGenHatch's Avatar
Default Re:
The fuel pump might need a full tank in order to prime itself.
Old May 22, 2004 | 08:03 AM
bossman032's Avatar
Default Re: Re: (FourthGenHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch &raquo;</TD></TR><TR><TD CLASS="quote">The fuel pump might need a full tank in order to prime itself.</TD></TR></TABLE>
yea I will try that asap
we opened the fuel filter line which goes to the rail it doesn't shoot gas but will try full tank before we do anything else.
Old May 22, 2004 | 08:57 AM
bossman032's Avatar
Default Re: Re: (bossman032)
anyone know how I can test the fuel pump???
let me know if u know how
Old May 22, 2004 | 03:23 PM
bossman032's Avatar
TTT
Old May 22, 2004 | 05:21 PM
you should be able to test fuel pump by getting a 5 gallon bucket of gas and getting wires ran to fuel pump with power (running it off a battery) and then put strainer into gas see what happens.
DEF
Old May 22, 2004 | 06:34 PM
bossman032's Avatar
Default Re: Re: (deftones0817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deftones0817 &raquo;</TD></TR><TR><TD CLASS="quote">you should be able to test fuel pump by getting a 5 gallon bucket of gas and getting wires ran to fuel pump with power (running it off a battery) and then put strainer into gas see what happens.
DEF</TD></TR></TABLE>
thanks will try that all it needs is power and ground??
whats the other wire..??
Old May 22, 2004 | 07:06 PM
hmm not sure I did this on a mustang fuel pump...not sure on crx. Dont know what 3rd wire is...maybe someone will inform us.
DEF
Old May 22, 2004 | 11:35 PM
bossman032's Avatar
TTT
Old May 23, 2004 | 05:38 AM
89dxhunchback's Avatar
When I put my TT stealth R/T fuel pump in my H/B I didn't use the civic pick-up tube.
I have to run almost a full tank all the time to get it to run. I swapped the pick-up tubes and now its fine.
While your at it, you may as well upgrade the power wire to the fuel pump, the supra pump is a voltage sucking beast.
Supra pump in a civic ??? hoping to run low 11's are we ??
Old May 23, 2004 | 08:58 AM
bossman032's Avatar
Default Re: Re: (89dxhunchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89dxhunchback &raquo;</TD></TR><TR><TD CLASS="quote">When I put my TT stealth R/T fuel pump in my H/B I didn't use the civic pick-up tube.
Supra pump in a civic ??? hoping to run low 11's are we ??</TD></TR></TABLE>
but the thing is the fuel gauge is reading littleless half tank but maybe u think I still have to pump full tank to get it to start?
also if I don't upgrade the voltage will the car still start?
we opened the number 12mm on fuel filter my friend was looking at the fuel see if its coming out he said its coming out very slowly!
Old May 23, 2004 | 10:01 PM
bossman032's Avatar
Old May 25, 2004 | 10:26 AM
bossman032's Avatar
anyone know how to wire it up with a relay??
because my stock wires are getting hellll hot
Old May 25, 2004 | 02:48 PM
bossman032's Avatar
TTT
Old May 25, 2004 | 04:51 PM
bossman032's Avatar
Yellow/Black Fuel Pump Power
Black Fuel Pump Ground
Old Jun 1, 2004 | 08:16 PM
bossman032's Avatar
supra fuel pump gets a
fyi: while changing the pump u should use a bigger gauge wires run it direct like a 10guage from the pump direct
also use the stock pickup screen. and get a vtec controller it takes to much gas when in vattack
trooper0641
Jul 13, 2005 08:21 PM
Hispeed
Jul 13, 2001 09:16 AM
