which one to tap on the o2 sensor
Old May 21, 2004 | 08:37 PM
GReddy SI's Avatar
Default which one to tap on the o2 sensor
I am trying to install A/F gauge , i need to tap to the o2 sensor
these 4 wires are coming from my o2 sensor,
which is the correct one to tap it from ?
Old May 21, 2004 | 08:39 PM
xhatchracerx's Avatar
Default Re: which one to tap on the o2 sensor (GReddy SI)
bump cause i would also like to know
Old May 21, 2004 | 09:01 PM
TwistedSI's Avatar
The off white one. It is a little thicker than the other 3.
Old May 21, 2004 | 10:38 PM
Dancing is Forbidden's Avatar
Default Re: (TwistedSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwistedSI &raquo;</TD></TR><TR><TD CLASS="quote">The off white one. It is a little thicker than the other 3.</TD></TR></TABLE>
Old May 21, 2004 | 10:54 PM
GReddy SI's Avatar
i tapped it off the white one but when it turns on it says rich with 1 bar there is that right?
or on the ecu what pin does it need to be at
Old May 22, 2004 | 12:47 AM
H22A EG6's Avatar
if it is a P30
D14 WHT PHO2S O2 sensor
http://tech2.hybridgarage.com/..._obd1
the one in the pics looks wht/blu it is "back up power" in D1 position
you need D14 solid white
check the link it is sum good info
Old May 22, 2004 | 05:03 AM
GReddy SI's Avatar
Default Re: which one to tap on the o2 sensor (H22A EG6)
the ecu is a p28 and motor is b16a2 us
Old May 22, 2004 | 05:05 AM
CivicSiRX's Avatar
i recommend tapping it off the white wire off the o2 sensor rather then at the ecu.
Old May 22, 2004 | 05:38 AM
GReddy SI's Avatar
Default Re: (CivicSiRX)
does anyone have a pic of the layout on the ecu
to tell me wheres d14 on the p28 ecu b16a2 swap
i am searching everywhere
Old May 22, 2004 | 05:49 AM
Cam79's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiRX &raquo;</TD></TR><TR><TD CLASS="quote">i recommend tapping it off the white wire off the o2 sensor rather then at the ecu.</TD></TR></TABLE>
Thats how ive heard to do it.
Old May 22, 2004 | 05:57 AM
GReddy SI's Avatar
Default Re: (C00SI)
found a pic ,
now where is d14. is it where it says c14?
Old May 22, 2004 | 06:15 AM
GReddy SI's Avatar
Default Re: (GReddy SI)
ok i just tapped it off that c14 and my a/f just has 1 light its on the right on rich and it doesnt move from there .
whats my problem now?&gt;
Old May 22, 2004 | 06:26 AM
GReddy SI's Avatar
anyone know why this is happening
Old May 22, 2004 | 09:28 AM
TwistedSI's Avatar
Is the car running and warm? When it is cold it will just hold one bar in the rich somewhere. When it reaches operating temp it should start sweeping at idle and doing its thing.
Old May 23, 2004 | 12:14 AM
H22A EG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GReddy SI &raquo;</TD></TR><TR><TD CLASS="quote">
found a pic ,
now where is d14. is it where it says c14?</TD></TR></TABLE>
the only CEU that is ABC is the OBDO
who ever made that is wrong i belive that only the C plug was for auto ECU so what is C14 is really D14 some one correct me if i am wrong
are you sure you did not tap the MAP sensor?
Modified by H22A EG6 at 4:23 AM 5/23/2004
Modified by H22A EG6 at 10:36 AM 5/23/2004
Old May 23, 2004 | 12:47 AM
civicshowracing65's Avatar
pretty much the basic rule i've seen for tegs and civics. It's the big white wire. Usually on the pin out closest to the passenger
Old May 23, 2004 | 01:21 AM
H22A EG6's Avatar
Default Re: which one to tap on the o2 sensor (civicshowracing65)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicshowracing65 &raquo;</TD></TR><TR><TD CLASS="quote">pretty much the basic rule i've seen for tegs and civics. It's the big white wire. Usually on the pin out closest to the passenger</TD></TR></TABLE>
lol dosent sound too smart to just grab what looks closest to passenger
b/c acording to that digram there are 2 white wire withen like a cm or 2
Old May 23, 2004 | 04:01 AM
menkio's Avatar
lol.. good info h-t
Old May 23, 2004 | 05:46 AM
bjscivic's Avatar
Try letting the car get to normal operating temp. After a couple minutes you should see it start to sweep.
Old May 23, 2004 | 06:31 AM
IS3Fifty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GReddy SI &raquo;</TD></TR><TR><TD CLASS="quote">does anyone have a pic of the layout on the ecu
i am searching everywhere</TD></TR></TABLE>
http://www.hybridgarage.com
Old May 23, 2004 | 08:36 AM
TwistedSI's Avatar
Damn, I can't believe how hard everyone is making this. Question has been answered but that appears to not be good enough.
Very simple, look at the wires off the ECU. There will be 2 white ones but one of them will be thicker and more off white in color, that is the one you want. Just take a look at your harness and you'll see how easy it is to locate. Lets not make this more difficult than it needs to be.
Old May 23, 2004 | 01:03 PM
H22A EG6's Avatar
he got it to work
951dc5
Apr 29, 2006 10:59 PM
JoshuaVTEC
Sep 17, 2005 10:25 AM
93FastLs
May 9, 2005 03:26 PM
B_1_8_hatch
Sep 3, 2003 08:20 AM
Hard2Find
Oct 7, 2002 02:59 AM
