b16 header 4-2-1 or 4-1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4by4inaCCord »</TD></TR><TR><TD CLASS="quote">you may need to get an aftermarket xmember or modify your stock xmember.</TD></TR></TABLE>
I stumbled upon pics somewhere out on the interweb but you actually grind it out a bit and it will fit no problems. If I wasn't so lazy I'd find the picture I saw.
I guess I am in the same situation. The guy I bought the car from, has the DC 4-1. At idle the car shakes due to the header on the crossmember. I am also getting that bogging feel at partial idle due to O2 postion on the collector. I have been told that I need to get a header proper O2's and that would go away. Do I need to cut my crossmember out more or is there a header that will position O2's properly, not touch the crossmember, and not dent the wallet too bad.
This is driving me nuts! All help and suggestions is greatly appreciated.
Josh
Josh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thegreydog »</TD></TR><TR><TD CLASS="quote">I guess I am in the same situation. The guy I bought the car from, has the DC 4-1. At idle the car shakes due to the header on the crossmember. I am also getting that bogging feel at partial idle due to O2 postion on the collector. I have been told that I need to get a header proper O2's and that would go away. Do I need to cut my crossmember out more or is there a header that will position O2's properly, not touch the crossmember, and not dent the wallet too bad.
Josh</TD></TR></TABLE>
Which vehicle do you have?
Uncle Ben's
Nov 21, 2007 06:08 AM
