what "T" for mech. oil pressure gauge
Old May 21, 2004 | 05:02 PM
a1320honda's Avatar
Default what "T" for mech. oil pressure gauge
im putting a mechanical oil pressure gauge in my 99 si, what "T" do i need to come off the oem oil pressure sending unit, or is there an easier way to hook this up?
Old May 21, 2004 | 06:41 PM
a1320honda's Avatar
Default Re: what "T" for mech. oil pressure gauge (a1320honda)
anyone?
Old May 21, 2004 | 06:45 PM
delslowed's Avatar
why mechanical?? why didn't u just go with digital or somthin a little easier..? my freind has it hooked up on his, i'll ask him how he hooked his up..
Old May 21, 2004 | 06:50 PM
misfitmagoofey's Avatar
Default Re: what "T" for mech. oil pressure gauge (delslowed)
ok now listen this might get cunfusing
your gunna look for where the oil presure sending unit is usaly on the block somewhere against the fire wall then your gunna drain your oil remove this then your gunna go to autozone and by a metric adapter for the oil pressure and the adapter is gunna go into this piece you just took off then your gunna hook a wire up to that and its gunna go back to the mechanical gauge u just put in to where it says sending wire
good luck any more help id b glad to assist i have put in alot of them
Old May 21, 2004 | 06:59 PM
a1320honda's Avatar
Default Re: what "T" for mech. oil pressure gauge (misfitmagoofey)
ok, i know how to hook it up, im just loking for the type of "T". like if i werw to go to a hardware store or something, i would tell them i need this brass "T" like thread pitch and stuff. thanks
Old May 21, 2004 | 09:14 PM
djfob's Avatar
I tee'd it off the back of the block where the stock oil pressure sender is with a tuner toys dual outlet block fitting. The mech gauge comes with a 1/8 fitting that works perfect on the fitting. Not sure if there's an easier way but I did it this way cuz I'm running my oils lines for my turbo from here anyways. But this will work nonetheless.
Old May 22, 2004 | 12:27 PM
realblag's Avatar
Try this. Ther work great and have the correct treads. http://shop.vendio.com/funinfe....html
Old May 22, 2004 | 01:22 PM
Frozen E's Avatar
H-T White Ops
Default Re: what "T" for mech. oil pressure gauge (realblag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realblag &raquo;</TD></TR><TR><TD CLASS="quote">Try this. Ther work great and have the correct treads. http://shop.vendio.com/funinfe....html</TD></TR></TABLE>
I have one. HIGHLY recommended. Either that thing or get one of those oil filter adapters. Do it the right way.
Old May 22, 2004 | 02:26 PM
a1320honda's Avatar
Default Re: what "T" for mech. oil pressure gauge (IslandSi)
can i get an oil filter adapter at like schucks or what?
Old May 22, 2004 | 02:42 PM
eL's Avatar
eL
Great Avatar
ALL YOUR BASE ARE BELONG TO US!
Old May 22, 2004 | 03:56 PM
Frozen E's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320honda &raquo;</TD></TR><TR><TD CLASS="quote">can i get an oil filter adapter at like schucks or what?
Check the FI forum. There was a thread about these a couple of days ago.
Actually here ya go. Good luck.
https://honda-tech.com/zerothread?id=867033
SoFresh1189
May 3, 2010 06:16 AM
torqueless
Apr 19, 2007 03:29 AM
untitled
Mar 11, 2003 02:27 PM
