could bent valves do anything to your cams?
Old May 21, 2004 | 05:00 PM
GSRBoi785's Avatar
Default could bent valves do anything to your cams?
i was just wondering if bent valves could ruin your cams or cause any damage at all
Old May 21, 2004 | 07:54 PM
slowdelsol's Avatar
yes they can if bad enogh it can flaten your lobes
Old May 21, 2004 | 08:21 PM
myke's Avatar
From: South LA...107th and fig to be exact...for the foo
Default Re: (slowdelsol)
maybe even break them
Old May 22, 2004 | 12:19 AM
Eddiebx's Avatar
in general you should be ok, unless ur runnign some really cheezy cams, i have bent my valves into a "z" shape, and the cams are still mint.
Old May 22, 2004 | 08:31 AM
mntuner2's Avatar
Default Re: could bent valves do anything to your cams? (GSRBoi785)
I would be more worried about the end of the cam where the cam sprocket bolts on. It would take alot of force to brake the cam, I would say the valve would bust apart before the cam cracks. I have seen two mitsubishi 1.8's(both neglected) in my shop now, both times cam gear bolt snapped off. ~$900 repair bill for new cam/gear , timing belt and water pump. But I have yet to see a broken OEM honda cam.
asbloodrunsblak
Oct 27, 2009 07:16 AM
hayabusa160
Sep 27, 2006 09:47 AM
loup05
Oct 2, 2005 12:19 PM
TurBoTeG
Aug 15, 2002 10:33 AM
86CRXSi
Jun 15, 2002 08:04 PM
