Help-Rattle in the rear?
Old Nov 8, 2001 | 05:39 AM
StinkyTofu's Avatar
Default Help-Rattle in the rear?
Ever since i got my car lowered, there has been a distinct sort of rattle in the back of my car. I'm not sure if its just something hitting my exhaust or something when i hit a bump, but does anyone have this problem? The sound is more distinct with a softer shock setting, so i have mine on stiff...anyways my set up is tokico illuminas/H&R sports. thanks.
Old Nov 8, 2001 | 05:49 AM
Greyout's Avatar
Default Re: Help-Rattle in the rear? (B-18C1)
I have this same problem, sounds like a fuct up bushing or something - someday I'll rip everything back out and try and figure it out.
Old Nov 8, 2001 | 09:42 AM
TurboSedan's Avatar
New User
Default Re: Help-Rattle in the rear? (JDM LUDE)
I have that same noise I think! I checked and it is my rear trailing arm bushings! They are fucked! I am going to replace them with ES poly at some point. The job is supposed to be a real bitch to do so I do not look forward to it!
Old Nov 8, 2001 | 12:41 PM
StinkyTofu's Avatar
Default Re: Help-Rattle in the rear? (97CivicFerio)
is it really something thats broken in my car? I mean i noticed this rattle the day i lowered my car. And my car is fairly new...Anyone else have this problem?
Old Nov 8, 2001 | 01:13 PM
TurboSedan's Avatar
New User
The bushings may have been stretched beyond their normal capacity due to the lowering. My bushings have over 102K miles on them so I know they are all close to, if not, dead already. I would check out your rear trailing arms and see if the bushing looks damaged at all. You'll need to jack it up and take the tire off to see it well enough.
Old Nov 8, 2001 | 01:59 PM
StinkyTofu's Avatar
this is a newbie question, but i wasn't the one to lower my car. What does the trailing arm look like? do you have a pic by any chance? thanks.
Old Nov 8, 2001 | 02:22 PM
Stephen's Avatar
Its possibly spring clatter...the dead coils of your spring coming together when you hit a bump. I had this and wedged some foam between the coils...rattle diminished 90%.
I'm going to remove my springs and wrap the coils with some tubing.
Jon Petersen
Feb 22, 2018 08:00 AM
yh23
10
May 31, 2005 05:11 PM
Slow
Dec 17, 2003 11:40 PM
Lui Kang
Jan 15, 2002 05:30 PM
chikai
Jul 11, 2001 10:14 AM
