Metal Shaving in Engine Oil
Old May 21, 2004 | 03:13 PM
AL ASPIRATED's Avatar
Default Metal Shaving in Engine Oil
Today I changed my oil and i foun little bits of metal shavings in it. This is the first time i seen it.
I was wondering is it normal to get a little bit of metal shavings in your oil?
I mean there are those magnetic drain plugs so im guessing its normal to have a little, im just thinking its normal ware.
Thanks
Old May 21, 2004 | 04:07 PM
doublejz's Avatar
Default Re: Metal Shaving in Engine Oil (AL ASPIRATED)
a little metal isn't too bad, just keep an eye on it. Depending on your driving it may just be wear and tear. If they are gold in color (like brass) I would worry. Bearings just appear to be silver but they are really brass. Therefore if you find gold shavings you could have spun a bearing. My d16z6 had metal on the drain plug on every oil change for like 40k miles and never had a porblem, until i snapped a rod
Old May 21, 2004 | 05:15 PM
Default Re: Metal Shaving in Engine Oil (doublejz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">a little metal isn't too bad, just keep an eye on it. Depending on your driving it may just be wear and tear. If they are gold in color (like brass) I would worry. Bearings just appear to be silver but they are really brass. Therefore if you find gold shavings you could have spun a bearing. My d16z6 had metal on the drain plug on every oil change for like 40k miles and never had a porblem, until i snapped a rod</TD></TR></TABLE>
ok thanks, it was really silver and didnt look like brass.
LS97Civic
Apr 24, 2012 07:48 AM
thakidd
Feb 10, 2008 12:53 AM
KooK
May 19, 2006 11:54 AM
sinister357
May 24, 2005 08:04 PM
explosive
Mar 14, 2005 06:31 AM
