Bad Tranny??????
Old May 21, 2004 | 02:00 PM
b16crx1's Avatar
Default Bad Tranny??????
when i come to a slow stop i hear a clunk sound coming from my front passenger side of my car. i thought it was a bad axle so i changed it and i thought that fixed the problem but it started doing it again today. so im think it might be my tranny. any input would be greatly appreciated
-Stephan-
Old May 21, 2004 | 03:31 PM
b16crx1's Avatar
ttt
Old May 21, 2004 | 08:49 PM
m3bluegsr's Avatar
Default Re: (b16crx1)
is it like a knocking, mine made like a knocking then it went away then it would sound like a bad bearing when decelerating. It turned out to be a bad mainshaft bearing. check everything and make sure all mounts are tight and listen for the noise outside the car when its parked.
Old May 21, 2004 | 11:45 PM
b16crx1's Avatar
yeah it only does it sometimes not all the time. i guess you can say its a knocking. is it hard to change the mainshaft bearing? what tranny do i get the bearing for if that the problem? i have a first gen jdm b16a
Old May 22, 2004 | 12:42 AM
hahagasdcrx's Avatar
does it make the noise on when you go over some bumps in the road?....4th gens steering racks have a plastic bushing that always seem to wear out on the passenger side causinge a knocking noise sometimes.......
http://www.slhondaparts.com/im...6.jpg part #10 rod end bushing . maybe this helps.....good luck
Old May 22, 2004 | 07:38 AM
b16crx1's Avatar
Default Re: (90crxzcgasd)
it makes like a rattling noise when im about to let out the clutch and hit the gas but i dont give it enough gas and the car shakes a little and sometimes when i go over bumps
Old May 22, 2004 | 07:52 AM
b16crx1's Avatar
is there anyway you can tell if #10 is my problem or not?
Old May 22, 2004 | 01:29 PM
b16crx1's Avatar
also i just remember the other day after i replaced the axle is when the noise started and it also started to pull to the right
Old May 22, 2004 | 02:03 PM
Malgerus's Avatar
Default Re: Bad Tranny?????? (b16crx1)
Sounds like the radius rod bolts could be too loose...
spotscivic
May 20, 2008 01:35 AM
Mleach
Apr 29, 2004 03:24 PM
Tchleung
Sep 16, 2003 02:08 PM
Frozen E
Aug 8, 2003 03:04 PM
cbrf-3
Apr 21, 2003 01:53 PM
