Car overheating any ideas.
Old May 21, 2004 | 12:43 PM
scoobyghost's Avatar
Default Car overheating any ideas.
I have a 93 civic lx and my car just started to overheat after i did a tune up on the car. It will start to overheat when my air conditioning is on. If I turn off the air and just turn the temperature gauge to hot the motor will cool down to pretty much normal(This is without the blower motor blowing air, just turning the guage to hot). Any ideas
Old May 21, 2004 | 01:17 PM
RobbieG35's Avatar
12 Years Strong
Default Re: Car overheating any ideas. (scoobyghost)
You should bleed the coolant. You could have an air pocket in there somewhere. It has happened to me before after flushing the radiator, I bled the coolant and it was fine
Old May 28, 2004 | 09:00 AM
MyKey's Avatar
Default Re: Car overheating any ideas. (HybridHatch88)
i doubt its the coolant ,unless you just flushed the system, if your AC is cold while your driving on the highway its def your radiator
Old May 28, 2004 | 09:04 AM
fabshybrid's Avatar
your thermostat could be clogged or bad, give it a shot and look. worst case is since u did a tune up the water pump was installed wrong and /or is leaking.
Old May 28, 2004 | 10:17 AM
JDMlyfestyle's Avatar
my guess is the thermostat. $19 from honda.
or you could get a new radiator. id suggest Del sol Dual core or a Fluidyne.
It also could be your coolant. try bleeding the system
Bill Leland
Jun 12, 2014 02:29 PM
B18c1vicrx
May 13, 2009 01:01 PM
corince06
Jun 11, 2008 12:48 PM
dhn
23
Jan 5, 2008 01:06 AM
drumsy
Sep 12, 2002 07:14 AM
