Hf upper control arm with integra knuckles? please help!
i did a b16 swap on my Hf. i read that i should use the stock UCA with the 91 integra hubs. i took them into the shop and he got them out but they were different sizes. what should i do???
also on the integra UCA the bolt for the lower controll arm is stripped. if i use the stock UCA the integra knuckle won't fit but if i use the integra UCA then the geometry will be off and i have a stripped bolt. what should i do??
hmm so the hf upper control arm was differnt size then integra upper control arm the bolt that connects it? So I'm guess that the si is what i was refering to. Im sorry about that. I guess you need to go hunting for some si ones...
DEF
DEF
on my 89 si.. i am using my stock UCA if you are going to buy stock UCA buy 90-91 as the ball joints are usually replaceable unlike 88-89
again.. only integra part i used was the knuckle
BigRex88
Jan 20, 2008 08:18 AM
coot_er
May 21, 2004 09:24 AM
