My b18c turbo project
Old May 21, 2004 | 12:09 PM
sky88's Avatar
Default My b18c turbo project
i am going on a b18c with 83 mm piston everything internal upgraded with a t3 4 e hybir 0.53 0.60 stage 3 turbin wheel ,please give me info for my tubo,now i am using a b18c non turbo but 83 mm shd i use 8 spark plug will it be too cold? 0.1 bar is equal to how many psi i am thinking to have 16 psi.Should i considere a 81 mm 81.5 or 83 mm please answer me
Modified by sky88 at 6:59 PM 5/22/2004
Old May 24, 2004 | 07:28 AM
sky88's Avatar
Default Re: My b18c turbo project (sky88)
some one please reply
Old May 24, 2004 | 08:05 AM
Andre's Avatar
1 Bar = 14.7 psi
Old May 24, 2004 | 08:08 AM
4-banging's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sky88 &raquo;</TD></TR><TR><TD CLASS="quote">i am going on a b18c with 83 mm piston everything internal upgraded with a t3 4 e hybir 0.53 0.60 stage 3 turbin wheel ,please give me info for my tubo,now i am using a b18c non turbo but 83 mm shd i use 8 spark plug will it be too cold? 0.1 bar is equal to how many psi i am thinking to have 16 psi.Should i considere a 81 mm 81.5 or 83 mm please answer me
Modified by sky88 at 6:59 PM 5/22/2004</TD></TR></TABLE>
#7 or #8 should be fine
14.5psi = 1 BAR
as far the other stuff...thats all up to you...but you can't bore an OEM block to 83mm, you'll need to sleeve it
Old May 24, 2004 | 08:09 AM
4-banging's Avatar
Default Re: My b18c turbo project (Andre)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andre &raquo;</TD></TR><TR><TD CLASS="quote">1 Bar = 14.7 psi
14.7 is atmospheric
Old May 24, 2004 | 08:15 AM
RyanEJ8's Avatar
PSI to BAR Converter
http://www.centauro-owners.com....html
Old May 25, 2004 | 09:50 AM
sky88's Avatar
Default Re: My b18c turbo project (RyanCivic2000)
so does it means if i am using 81 mm is better what is the difference of the piston size?
Old May 25, 2004 | 12:53 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sky88 &raquo;</TD></TR><TR><TD CLASS="quote">so does it means if i am using 81 mm is better what is the difference of the piston size?</TD></TR></TABLE>
The difference between an 83mm and 81mm piston is about 2mm.
Old May 25, 2004 | 01:01 PM
1316130057's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sky88 &raquo;</TD></TR><TR><TD CLASS="quote">i am going on a b18c with 83 mm piston everything internal upgraded with a t3 4 e hybir 0.53 0.60 stage 3 turbin wheel </TD></TR></TABLE>
Good sized turbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sky88 &raquo;</TD></TR><TR><TD CLASS="quote">a t3 4 e hybir 0.53 0.60 stage 3 turbin wheel</TD></TR></TABLE>
I don't see what it is that you wanted to know about it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">shd i use 8 spark plug will it be too cold</TD></TR></TABLE>
Nah. It's fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">0.1 bar is equal to how many psi i am thinking to have 16 psi.</TD></TR></TABLE>
0.1bar = 1.4696psi. On the other hand, 1 bar = 14.696 psi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Should i considere a 81 mm 81.5 or 83 mm please answer me </TD></TR></TABLE>
How would we know? What do you want to achieve with the engine. Also, I'm curious if your keyboard is missing some keys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">so does it means if i am using 81 mm is better what is the difference of the piston size?</TD></TR></TABLE>
Aside from the physical differences, a larger diamater piston will deliver more hp, more torque, and burn more gas.
Old May 25, 2004 | 05:08 PM
MachAF's Avatar
Default Re: My b18c turbo project (1316130057)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1316130057 &raquo;</TD></TR><TR><TD CLASS="quote">
if you wanna get technical 1 bar = 14.503
Not sure where you found your answer.
Old May 26, 2004 | 05:08 AM
4-banging's Avatar
Default Re: My b18c turbo project (MachAF)
NO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MachAF &raquo;</TD></TR><TR><TD CLASS="quote">
Not sure where you found your answer.</TD></TR></TABLE>
I think he's thinking of Atmospheric Pressure
14.7psi = AP
14.5psi = BAR
14.2 = kg/cm2
Old May 26, 2004 | 08:27 AM
1316130057's Avatar
Default Re: My b18c turbo project (4-banging)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4-banging &raquo;</TD></TR><TR><TD CLASS="quote">
14.7psi = AP
14.5psi = BAR
14.2 = kg/cm2</TD></TR></TABLE>
W3rd. If one bar is subbosed to equal 1atmosphere, needless to say I interpreted 1 bar as 14.696 (101.3kPa). As it turns out, it's rounded off to 14.5 (100.0kPa) for ease of use...Brilliant!!
Old May 26, 2004 | 09:29 AM
sky88's Avatar
i am targetting 400-500 whats is the best piston?what i mean is what is the best size
Modified by sky88 at 5:44 PM 5/28/2004
Old May 28, 2004 | 02:14 AM
Andre's Avatar
http://en.wikipedia.org/wiki/Turbocharger
"At 100% efficiency, a turbocharger providing 100 kPa (= 1 Bar or 14.7 PSI) of boost would effectively double the power of the engine."
Old May 28, 2004 | 07:37 AM
1316130057's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andre &raquo;</TD></TR><TR><TD CLASS="quote">http://en.wikipedia.org/wiki/Turbocharger
Andre, I was on the same school of thought, but through the dumbification of the world, I saw that the generally accepted kPa for 1 BAR was 100kPa. Just to make things easy for the simple mind. I'm still going ot take to the grave that 1Br = 14.696psi which is one atmosphere, but now I am aware that in some cases, some parties are propigating that 14.5 = 1 atmosphere or 1 bar.
jdm_spoon_dc2
May 4, 2006 04:44 PM
