HELP!!! what ecu is this
Old May 21, 2004 | 10:26 AM
crazyimport's Avatar
Default HELP!!! what ecu is this
i was told this was p28 chipped for my boost..... nothing looks like its soldered on for the eprom
he said it was just a p06 case with p28 guts.....
tell me what u think thanx
Old May 21, 2004 | 10:50 AM
allmotaeg6's Avatar
that looks like a regular p06 to me
Old May 21, 2004 | 10:57 AM
boomslang's Avatar
Default Re: (pr0ject Eg6)
It's a P06 board. Look at the barcode label on the connector. "37820-P06-C02"
Old May 21, 2004 | 10:58 AM
Default Re: (boomslang)
ok i have a b16a2 turbo with itr valvetrain, walbro fuel pump and 440cc rc injectors....
i should NOT b running my car with this ecu .... ****
Old May 21, 2004 | 11:13 AM
mattssi's Avatar
Default Re: (crazyimport)
I can cnfirm that upon looking at that, it is a p-06 ecu.
Old May 21, 2004 | 12:19 PM
Default Re: (mattssi)
can these ecu's be programmed for b16a's ?
Old May 21, 2004 | 12:55 PM
TwoK4drSi's Avatar
Get a p28. Do it right the first time
Old May 21, 2004 | 01:00 PM
Jim Truett's Avatar
Default Re: (TwoK4drSi)
It's a P06 that was converted to run VTEC. Notice the high-side switch at position IC14. As long as there is a P28, P30 or P72 based program on the ROM it will run VTEC. Also the code 301 on the MCU says it is definitely a P06.
it was supposed to be a p28
did you not read
Old May 21, 2004 | 01:01 PM
Default Re: (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">It's a P06 that was converted to run VTEC. Notice the high-side switch at position IC14. As long as there is a P28, P30 or P72 based program on the ROM it will run VTEC. Also the code 301 on the MCU says it is definitely a P06.</TD></TR></TABLE>
thanx.... so it is chipped then
Old May 21, 2004 | 02:17 PM
Shaun's Avatar
good info, most people are not aware of this
Old May 21, 2004 | 03:52 PM
Default Re: (Shaun)
can you circle this part??
civic-one
Jun 12, 2009 12:36 PM
obuhmyuh
29
Feb 15, 2008 01:00 PM
leighton1245
Feb 11, 2008 05:23 PM
nota-eg
Jun 24, 2005 08:28 AM
^Sammy]!.
Jul 16, 2004 09:54 PM
