Anyone Dyno over 750+hp?
If you know anyone with a dyno sheet and a pic of the car that pushes more than 750hp to the wheels please post it! People at work don't think it is possible to have a 4 cyl with over 750hp that can be street driven.
Shaughn
Shaughn
Ground Zero did that dude Duc's civic at 712whp and that was on a Mustang dyno. so its prob pretty close. Its a street car too . they have the actual run on video and they pan over to the computer.
http://oregonstate.edu/~uyemur...o.mpg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd »</TD></TR><TR><TD CLASS="quote">That was a bad *** civic</TD></TR></TABLE>
Was? Is it not together anymore?
The guy that doesn't believe you can make a Honda 4 Cyl. over 750hp is a Honda Rep. He says it takes hundreds of thousands of dollars to make one. Yeah....to make a reliable 500 mile IRL car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDAofPOKY »</TD></TR><TR><TD CLASS="quote">The guy that doesn't believe you can make a Honda 4 Cyl. over 750hp is a Honda Rep. He says it takes hundreds of thousands of dollars to make one. Yeah....to make a reliable 500 mile IRL car. </TD></TR></TABLE>
Reliable is a very subjective word.
Smarter than you
who cares if a street car makes 750 horsepower if it aint doin anything with it. Why don't u show him Jason Hunt's CRX running 9's instead?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 »</TD></TR><TR><TD CLASS="quote">who cares if a street car makes 750 horsepower if it aint doin anything with it. Why don't u show him Jason Hunt's CRX running 9's instead?</TD></TR></TABLE>
Exactly! And that car is nowhere near 750whp and doesn't need it either!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed »</TD></TR><TR><TD CLASS="quote">Exactly! And that car is nowhere near 750whp and doesn't need it either! </TD></TR></TABLE>
Shhh, don't give out secrets, they do need that much hp.
Seriously though you could make 750 if you really wanted to(and have the resources obviously), but there would be absolutely no use for it unless you like to spin forever.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rhman19 »</TD></TR><TR><TD CLASS="quote">
Seriously though you could make 750 if you really wanted to(and have the resources obviously), but there would be absolutely no use for it unless you like to spin forever.</TD></TR></TABLE>
SFP car got over 750whp I believe, it runs fast sometimes then sometimes has problems. That caronce it is COMPLETELY DIALED IN CONSISTENTLY will be a force to be reckoned with also BUT I do not think the 750whp is needed right now with suspension set ups and our current street car set ups. One day we will TOTALLY figure out how to completely beat the laws of physics and run like a RWD car or close.
Seriously though you could make 750 if you really wanted to(and have the resources obviously), but there would be absolutely no use for it unless you like to spin forever.</TD></TR></TABLE>SFP car got over 750whp I believe, it runs fast sometimes then sometimes has problems. That caronce it is COMPLETELY DIALED IN CONSISTENTLY will be a force to be reckoned with also BUT I do not think the 750whp is needed right now with suspension set ups and our current street car set ups. One day we will TOTALLY figure out how to completely beat the laws of physics and run like a RWD car or close.
One of the "strongest" 4cyl streetcars is a Ford Sierra Sapphire Cosworth own by Ruudracing. 710,2 hk-760nm-1,73 bar.
This engine just will not die...
It started its life in a black cossi, went on to a silver cossie, and now it is being the senter of a BMW...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote">Ground Zero did that dude Duc's civic at 712whp and that was on a Mustang dyno. so its prob pretty close. Its a street car too . they have the actual run on video and they pan over to the computer.
http://oregonstate.edu/~uyemur...o.mpg</TD></TR></TABLE>
WOW that dyno pull is sick
http://www.jgenginedynamics.com/dynotests7
those engine just need some more RPM and they can get into the 800whp, that's if they can keep up those tq numbers!!
i've seen on tv a top fuel car using a 4cyl making over 2K whp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSMC »</TD></TR><TR><TD CLASS="quote">http://www.jgenginedynamics.com/dynotests7
i've seen on tv a top fuel car using a 4cyl making over 2K whp</TD></TR></TABLE>
Bob Norwood's most likely!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicRyda2k »</TD></TR><TR><TD CLASS="quote">
whatever did happen to Duc and the GZ crew?</TD></TR></TABLE>
They are still around and Ducs car is still together. Last I talked to them they were having problems with the F.A.S.T. and the MSD box breaking up spark here and there. Once that thing is dialed in it is going to be a beast.
-Ryan
-Ryan
those motors need to be rebuild tho like almost after 1 race i think.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J337_UNIT »</TD></TR><TR><TD CLASS="quote">those motors need to be rebuild tho like almost after 1 race i think.</TD></TR></TABLE>
yes this is streetable
nah fo real, yes those engine need to be checked up evry day, maybe not evry race, since they are being used for drag, but maybe every 5-10passes
