accord hesitation question
Old May 21, 2004 | 06:59 AM
zdr262's Avatar
Default accord hesitation question
i placed this on the accord forum but i think its more of a tech question than just a accord question... my boy has a 2000 honda accord lx 4cyl auto and it has a stock intake. we removed the bottom box below intake filter that is in the fender and it ran fine for like a week every day to work and even a run to LA (1 1/2hr drive)....now it wont rev past 5k and it feels flat when he jumps on it.... the car feels like it has no power compared to stock.... we reset the computer and also changed the spark plugs and it still wont rev, no cel, no smoke, and even in neutral it wont rev past 5k ... could it have to do with the resonstor box(it doesnt have any sensors in it) or what are some other things that would cause that...any suggestions would be appreciated
Old May 21, 2004 | 02:40 PM
zdr262's Avatar
Default Re: accord hesitation question (zdr262)
bump
Old May 22, 2004 | 07:23 AM
zdr262's Avatar
now here is another problem.... last night as we were driving home from the downtown his car wouldnt accelerate at all on the freeway so we get off and it will not rev past 1.5k and it doesnt have any power we left the car on a hill because it didnt have the power to get up the hill..... im going to go and get the car now and hope after it cools down itl have some power ...... but no cel, its not overheating, no smoke,...anybody have anysuggestions for me to try when i get the car home?
Old May 22, 2004 | 11:08 AM
TIRENECK's Avatar
check ur air filter.
Old May 22, 2004 | 03:32 PM
rollinchassis's Avatar
does you car have any code at all. does the car feel like that when the car get hot or same as when you start the car up. Have you change your fuel filter, cap, rotor and check you spart plug to see if there are all black.
Old May 22, 2004 | 03:33 PM
Default Re: accord hesitation question (rollinchassis)
sound like you cat might be burn,
Old May 22, 2004 | 07:49 PM
zdr262's Avatar
yea we pulled the plugs and did a compression test, because i thought maybe it was a head gasket going south, the compression test was 185 all the way across. the plugs were black so its running hella rich. he was talking about bottom'ing out right before this started so if he damaged his cat that might cause this? no check engine light, noticed alittle smoke today smells like fuel but its verry little barly enough to notice.
Old May 23, 2004 | 07:51 AM
dwayne.eaddy's Avatar
player that is a fuel filter problem. i drive trk and trailer and that is happens when we get bad fuel. to much water in the fuel. chk your filter u should be ok
Old May 23, 2004 | 10:33 AM
zdr262's Avatar
rollingchassis you are the man thanks alot i would have never thought about the cat but right when we unhooked the downpipe to the cat it started right up and drove home fine thanks for all the info if you are ever in so cal i owe you a beer cheers to ya
Old May 24, 2004 | 09:21 PM
alright i hold you up that my name is Thang team str racing/rollinchassis.....
fldones163
Mar 23, 2012 11:01 PM
zdr262
May 20, 2004 09:52 PM
juicedricer
Jul 25, 2003 10:18 PM
