Having a problem with idle surge on ITR Please Help
Old Nov 7, 2001 | 11:27 PM
NeXtLeVeL_TyPe_R's Avatar
Default Having a problem with idle surge on ITR Please Help
I just installed a Ericks TB and STR intake Manifold on my car
I am getting a idle surge occasionally from 1500 down to 1000
The TPS sensor is set right at .5 closed to 4.5-5.0 WOT
My Idle control Valve gets very very hot
I had to provide it with coolant myself because the Ericks TB doesnt have provisions for coolants lines which dont matter that much but the STR doesnt have one either
I teed into one off the coolant lines to try and create a loop threw the Idle Control Valve.
Is it possible that i either have the two coolants lines going into the Idle control valve reversed or can it be contributed to the Tee in.. at a bad location
Anyone have any suggestions where i can get a good coolant line to tee into to provide for the Idle control vavle if thats even my problem
Someone please help
I will try to post a pic below of where i teed in
(you can see the tee with hose clamps at every end)
[IMG][/IMG] http://www.cleartaillights.com/eurot...s/Coolant6.jpg
Old Nov 8, 2001 | 11:25 AM
earl's Avatar
Default Re: Having a problem with idle surge on ITR Please Help (NeXtLeVeL_TyPe_R)
I'd look for a vacuum leak to cure the surging.
xlusiveracer
40
Jan 23, 2017 09:32 PM
juanchoenuncrx
Aug 8, 2007 09:16 PM
LD_EGSICK
15
Aug 5, 2003 10:35 PM
hybrid901
May 29, 2003 07:20 AM
NeXtLeVeL_TyPe_R
Nov 8, 2001 01:24 PM
