Having a Problem with idle surge can anyone help?
I just installed a Ericks TB and STR intake Manifold on my car
I am getting a idle surge occasionally from 1500 down to 1000
The TPS sensor is set right at .5 closed to 4.5-5.0 WOT
My Idle control Valve gets very very hot
I had to provide it with coolant myself because the Ericks TB doesnt have provisions for coolants lines which dont matter that much but the STR doesnt have one either
I teed into one off the coolant lines to try and create a loop threw the Idle Control Valve.
Is it possible that i either have the two coolants lines going into the Idle control valve reversed or can it be contributed to the Tee in.. at a bad location
Anyone have any suggestions where i can get a good coolant line to tee into to provide for the Idle control vavle if thats even my problem
Someone please help
I will try to post a pic below of where i teed in
(you can see the tee with hose clamps at every end)
[IMG][/IMG] http://www.cleartaillights.com/eurot...s/Coolant6.jpg
Someone please help
Try IM 2fknfst - he had the same problem with his aftermarket TB - and was supposed to comment on the cure/solution - but never did.....bastard.
hmm i have that same prob
I thought it was the cams
I have the skunk 2 manifold and the billet holley 68mm
any thoughts out there?
once in a blue moon it idles fine
but thats for about 3 minutes
LD_EGSICK
15
Aug 5, 2003 10:35 PM
NeXtLeVeL_TyPe_R
Nov 8, 2001 11:25 AM
