Fuel Pump Kill Switch
Old May 20, 2004 | 10:10 PM
jedubz's Avatar
Default Fuel Pump Kill Switch
Okay, so I plan on running a fuel pump kill switch in my car, I've already got an alarm but I know with thieves these days you can never be too safe.
What I was planning on doing was splice the positive and negative wires, feed both ends to a switch, so when the switch is "On" it completes the circuit, allowing the fuel pump to well... pump. Here's what I see.
I used a light with a ground point and only got light from the yellow wire I'm pointing to, so I'm assuming that's positive signal. I just need to know which wires to cut to install the switch.
Old May 20, 2004 | 10:12 PM
erikiksaz1's Avatar
Default Re: Fuel Pump Kill Switch (jedubz)
Shoot, i forgot the exact color, but if you search around there's several good tutorials. I think i used one from the EG forum, the only difference was that our power wire was a different color.
Old May 20, 2004 | 10:20 PM
kyle h.'s Avatar
Default Re: Fuel Pump Kill Switch (erikiksaz1)
if you've got anything done to the car, you might as well rewire your fuel pump, and connect the switch to the relay..
Old May 20, 2004 | 10:24 PM
civickiller's Avatar
Default Re: Fuel Pump Kill Switch (kyle h.)
i believe its the yel/blk wire, put a switch on that wire. its easy cut the wire, put the switch in the middle connect other side to other connector on switch, all done.
just make sure its the one that goes to power the pump and not the fuel gauge
Old May 20, 2004 | 10:54 PM
jedubz's Avatar
Default Re: Fuel Pump Kill Switch (civickiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">i believe its the yel/blk wire, put a switch on that wire. its easy cut the wire, put the switch in the middle connect other side to other connector on switch, all done.
just make sure its the one that goes to power the pump and not the fuel gauge</TD></TR></TABLE>
And how do I do that?
Old May 20, 2004 | 10:58 PM
erikiksaz1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jedubz &raquo;</TD></TR><TR><TD CLASS="quote">
Found it.
http://www.courtlukens.com/cutoff_switch.htm
Old May 20, 2004 | 11:31 PM
its easy, take the wire off the connector underneath the seat, and plug the connector back on and turn the key, do you hear the fuel pump prime ?
and the wiring of the switch is easy
Old May 20, 2004 | 11:50 PM
Malgerus's Avatar
One way I've seen it done is to take the yel/black power wire and trace it back to the main relay, and do it from under the dash, so you can hide it better.
Old May 21, 2004 | 05:04 AM
MooreBoost's Avatar
Default Re: Fuel Pump Kill Switch (Mr. S)
When I did it in my Integra it was a yellow wire with a black stripe, all I did was cut it, splice the two ends, run a wire from one end to a switch, then another wire from the switch to the other end of the yellow/black wire, never ran a relay and it was fine for months.
Old May 21, 2004 | 07:39 AM
keithv's Avatar
Default Re: Fuel Pump Kill Switch (tegunderpressure)
I always wondered why people did fuel pump kill switches. If the kill switch fails during driving, your engine won't get fuel. Do you know what happens next? Boom.
I'd use another signal to protect my car, but that is just me.
Old May 21, 2004 | 10:12 AM
CyniKal.Mindset's Avatar
Default Re: Fuel Pump Kill Switch (keithv)
its a mechanical switch... on or off...if it fails its either not gonna turn off or its gonna stay on which is fine cuz then its gonna act like stock...I dunno what kinda switch you would use that has an automatic breaker in it or somethin that shuts off when it fails...cuz the switches we use are 25amp mechanical switches...like a heavy duty foglight switch
Old May 21, 2004 | 01:02 PM
erikiksaz1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithv &raquo;</TD></TR><TR><TD CLASS="quote">I always wondered why people did fuel pump kill switches. If the kill switch fails during driving, your engine won't get fuel. Do you know what happens next? Boom.
I'd use another signal to protect my car, but that is just me. </TD></TR></TABLE>
Boom when the engine doesn't get fuel? How would it be possible for anything to explode without some sort of fuel anyways?
And if it does fail, all you need is some extra wire and some scissors. Cut where you spliced in the connector and reconnect the factory wires stock style.
Old May 21, 2004 | 04:15 PM
FULL-RACE EP3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithv &raquo;</TD></TR><TR><TD CLASS="quote">I always wondered why people did fuel pump kill switches. If the kill switch fails during driving, your engine won't get fuel. Do you know what happens next? Boom.</TD></TR></TABLE>
Wouldnt it just shut off???
Old May 21, 2004 | 04:21 PM
StupidSlowRSX's Avatar
ROFL
Yes, the engine just turns off, I know the hard way ( 4k RPM on highway Fuel Pump died )
Walbro owns :]
Old May 21, 2004 | 04:47 PM
jedubz's Avatar
I always wondered why people talk out of their asses when the don't actually know what happens if an engine's fuel is cut off. Do you know what happens after people post wrong information about something they don't understand? Flame.
Old May 21, 2004 | 04:58 PM
well he is right in a sense that if yoru were runnin a high boost car and you cut the fuel its bad for the motor, it runs lean for that 1 sec, or so they say. other say theres no fuel at all so it doesnt combust so it doesnt run lean cause its not runnin. idk what your take on it is
Old May 21, 2004 | 05:11 PM
sporkcrx's Avatar
I've been on the highway at full boost and had the pump cut out, it survived fine Same thing with idling and normal driving, it just dies off
Old May 21, 2004 | 05:43 PM
HamiltonRex's Avatar
Default Re: Fuel Pump Kill Switch (sporkcrx)
I seen a DIY thing on the next about a kill swich. it was very good. It was using magnets and stuff that you swipe across your door and a magentic swich would open/close.
I cant find the link though!!
Old May 21, 2004 | 09:48 PM
sporkcrx's Avatar
Default Re: Fuel Pump Kill Switch (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">I seen a DIY thing on the next about a kill swich. it was very good. It was using magnets and stuff that you swipe across your door and a magentic swich would open/close.
I cant find the link though!!</TD></TR></TABLE>
Who's your daddy?
http://www.autospeed.com/cms/A_0059/article.html
Old May 22, 2004 | 05:32 AM
RapeV-8's Avatar
is it important to have a rely on the switch??? i m not good with electirc stiff
Old May 22, 2004 | 05:55 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">
Who's your daddy?
http://www.autospeed.com/cms/A_0059/article.html</TD></TR></TABLE>
Thanks!
-Eric
Old May 22, 2004 | 06:09 AM
model x's Avatar
just a suggestion; connect the fuel pump's ground to a switch instead of the power wire.
Old May 22, 2004 | 09:14 AM
Default Re: Fuel Pump Kill Switch (model x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by model x &raquo;</TD></TR><TR><TD CLASS="quote">just a suggestion; connect the fuel pump's ground to a switch instead of the power wire.</TD></TR></TABLE>
Umm.. No.
You ALWAYS SWICH THE HOT WIRE.
-Eric
Old May 22, 2004 | 01:31 PM
model x's Avatar
Umm.. No.
-Eric</TD></TR></TABLE>
Umm.. Why?
There's many cases where manufacturers switch the ground.
BTW why do you insist on coming off as an idiot? Your making the rest of us Canadians look bad
Old May 22, 2004 | 05:03 PM
Umm.. Why?
Name one please.
When you swich a ground, neutral, return whatever. (even on 120V) It can backfeed if something else comes in contact with it, therefor blowing up or burning out things.
You just dont switch the ground. Its common knowledge. You want NO power at the device when it is turned OFF.
Yeah and your so right about canadians. Your obviously ignorant as well, please refrain from using personal attacks on me. It does in now way help prove you are right.
-Eric
