Rev. LiMiTer Problems.....
i'm having problems with my rev. limiter or maybe my ecu... gotta b16a in a 89 hatch and PR3 ecu... rev. limiter kicks in sometimes 8000rpm like it should, and most of the time before 8000 rpms.... like at 7500 rpm or 7000 rpm.... its a manual PR3.... confused..... oh, and got a V-AFC hooked up too... if you got some answers... let me know....
rev limit will be @7000 rpm when the coolant temperature is low. When your coolant gets to a certain temperature ( cant remember the temp. right now ) then it will run with the higher rev limit @8200 rpm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wtsexton »</TD></TR><TR><TD CLASS="quote">VTEC won't kick in either until the engine is warmed up.</TD></TR></TABLE>
It will if you have the vafc hooked up
yeah i've been having a coolant problem... dam radiator keeps leaking from the top... got a new radiator to install in two days.... thanks
BlackCivSi
21
May 4, 2004 08:24 PM
