General Cam Q's
Old Nov 7, 2001 | 10:00 PM
comptechgsr's Avatar
Default General Cam Q's
can someone please explain to me lift, duration, and the use of degrees---as in i have so and so degrees, 302 degrees?
thanks,
d
Old Nov 7, 2001 | 10:20 PM
FAST94GSR's Avatar
New User
Default Re: General Cam Q's (comptechgsr)
lift is the amount of opening the valve opens.
duration is how long the valve stays open, the bigger the duration the more the valve stays open to allow more air to get into the chamber. Duration is how long in crankshaft degrees the valve stays open.
When lift and duration are increased to lets say 12.5mm and 273 degrees duration you need big compression like 12:1 cause when the valve opens that bleeds out the compression in the cylinder.
Hope that helps.
[Modified by FAST94GSR, 2:21 AM 11/8/2001]
rotascircuit
Dec 16, 2009 02:58 PM
garyc17
May 4, 2007 08:29 PM
95gsr
Apr 8, 2003 07:20 AM
SamC
Feb 1, 2003 08:47 AM
Cow
Jun 26, 2002 04:12 PM
