what to do to my new civic 2002 si
If you're going turbo, you shouldn't have bought the CAI and the header. If you want to continue on just bolt ons, you can install some Energy suspension motor mount inserts. Then, you can buy a hi flow cat with Casper's O2 sensor simulator. After that, you can do a Hondata reflash. Work on your suspension is always a plus, 22mm rear sway bar (some options to choose from). Full coilovers or springs, don't be ghetto so don't cut or heat them. If more power is what you want, you can do a K20A2 head swap and if you want, you can also drop in the 6 speed transmission or you can just swap in the whole K20A2. I'm sure there's more but I'm done writing.
they both have good points ur jes wasting money
thou art sinning
id say u jes do all motor swap it with a type s motor or da k20r either 1 haul ***
thou art sinning
I think you should use the seach function on this board, and over at http://www.ephatch.com before you do/buy anything.
I agree With "mhx".... with the mods you have i would definately go with the supercharger. Or a head swap could be a good idea too
If you were to get a turbo that header would've been a watse of $...but with the supercharger you'll still get a horsepwer gain from the header
That's what I'm planning to do
