muffler volume vs. tip length - question
Old May 20, 2004 | 09:39 PM
CrazyModGSR's Avatar
Default muffler volume vs. tip length - question
Is it true that that on a given muffler on the same vehicle, a muffler with a shorter tip will be louder than the same muffler with a longer tip? ie: does volume decrease with longer tip length?
Old May 23, 2004 | 03:09 PM
Default Re: muffler volume vs. tip length - question (CrazyModGSR)
bump
Old May 23, 2004 | 03:28 PM
JG Luder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrazyModGSR &raquo;</TD></TR><TR><TD CLASS="quote">Is it true that that on a given muffler on the same vehicle, a muffler with a shorter tip will be louder than the same muffler with a longer tip? ie: does volume decrease with longer tip length?</TD></TR></TABLE>
Generally, no. Tips can act as resonators.
Take redneck trucks for example. I do exhaust work at my shop sometimes and if you run straight pipes with no tip, vs straight pipes with an 18" long 4 1/2" tip, the one with tips will DESTROY the other. And also probably destroy your hearing while your at it. It's kinda crazy how it works.
My opinion (others may disagree):
Typically speaking, Honda's don't flow enough air to really be able to tell the difference in noise from having a 4" long tip, or not having one at all. It may change the tone, but that's about it.
Get a muffler with a silencer if you're worried about noise.
Old May 23, 2004 | 03:59 PM
Default Re: muffler volume vs. tip length - question (Lone Luder)
I definitely want to get a silencer, but not sure if it will be to restrictive of exhaust flow, with my turbo and all.
olddohc
Jan 13, 2012 01:28 PM
crxhondata
May 23, 2008 06:21 AM
lowRIDAH
Oct 2, 2005 01:25 PM
BLACK97EKCOUPE
Jun 6, 2004 01:43 PM
