speedo messed up...any suggestions
Old May 20, 2004 | 09:01 PM
BumpinVTEC's Avatar
Default speedo messed up...any suggestions
i have a si cluster in a dx, all wires connected, checked speed sensor and its nice and snug....its wired like it'll just die when i'm driving i got to tap the cluster repeatedly then the speedo needle goes back to normal...anyone know whats wrong with it
Old May 20, 2004 | 09:10 PM
JDM PRO's Avatar
Default Re: speedo messed up...any suggestions (BumpinVTEC)
that happened on my crx and i figured that the cluster is just too old and worn out
Old May 20, 2004 | 09:34 PM
Ricey McRicerton's Avatar
Default Re: speedo messed up...any suggestions (JDM PRO)
Sounds like you got a broken cluster.
Old May 20, 2004 | 10:14 PM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BumpinVTEC &raquo;</TD></TR><TR><TD CLASS="quote">i have a si cluster in a dx, all wires connected, checked speed sensor and its nice and snug....its wired like it'll just die when i'm driving i got to tap the cluster repeatedly then the speedo needle goes back to normal...anyone know whats wrong with it</TD></TR></TABLE>
well if the speedo on ur stock DX cluster works, and the one on ur si doesnt, the si speedo is probably busted. you can take the speedo out of the dx cluster and put it in the SI one. btw, i have an extra CX speedo if ur interested
Old May 20, 2004 | 10:19 PM
trooper0641's Avatar
i had this problem...
how to fix it : turn on your car to normal idle....and then with the cluster window off...pull out the needle out of the speedo...and then just set it to 700-800 rpm where it should be. It works trust me.
Old May 20, 2004 | 10:40 PM
BumpinVTEC's Avatar
Default Re: speedo messed up...any suggestions (trooper0641)
thanks
Old May 21, 2004 | 01:30 AM
IWearMyKswiss's Avatar
New User
does your stock cluster work just fine? if your stock cluster works fine then the new cluster is defective
but if your stock cluster is doing the same as your new cluster,..then its a messed up VSS,..have you gotten water on it lately?? i was doing a engine degrease one day,..my VSS got wet,..my speedo would die out on me while driving,..after a day or so the VSS dried out and the speedo was working perfectly fine again
Old May 21, 2004 | 11:23 PM
BumpinVTEC's Avatar
how do pull it out, i tried to do what you said but the needle doesnt seem to move and i dont really want to **** up anything
fred200
Honda Civic (2006 - 2015)
Aug 11, 2015 07:08 AM
kaboomwoom
Mar 12, 2008 01:06 AM
freshekhatch
Feb 15, 2008 08:23 PM
Mr.Meowsome
12
Dec 4, 2007 05:23 PM
92eg6lsvtec
Aug 27, 2006 11:59 PM
