Opinions on ITR Transmission with ATS 4.9 FD
Old May 20, 2004 | 08:36 PM
baxter04's Avatar
Default Opinions on ITR Transmission with ATS 4.9 FD
Just like the topic says. Thanks for any input.
Old May 20, 2004 | 11:28 PM
SuperTwinz's Avatar
Default Re: Opinions on ITR Transmission with ATS 4.9 FD (baxter04)
What are you using the tranny for? Street/drag or straight drag? A 4.9 in a usdm ITR tranny is pretty short.
Old May 20, 2004 | 11:42 PM
baxter04's Avatar
Default Re: Opinions on ITR Transmission with ATS 4.9 FD (SuperTwinz)
full time drag car.
Old May 20, 2004 | 11:47 PM
SuperTwinz's Avatar
I would run 15" slicks depending how much power you make.
Old May 20, 2004 | 11:54 PM
baxter04's Avatar
Is there a difference between the JDM and the USDM transmissions as far as gear ratios? Our projected HP is in the 230-260 range. Would you reccomend this tranny w/ our HP?
Old May 21, 2004 | 07:18 AM
Casey's Avatar
the jdm has a little bit longer 4th gear. it will be a very quick tranny with that power, and youd probably be running bigger than 24"s even with a higher redline
Old May 21, 2004 | 04:15 PM
H25's Avatar
H25
Default Re: Opinions on ITR Transmission with ATS 4.9 FD (Casey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey &raquo;</TD></TR><TR><TD CLASS="quote">the jdm has a little bit longer 4th gear. it will be a very quick tranny with that power, and youd probably be running bigger than 24"s even with a higher redline</TD></TR></TABLE>
the us and jdm itr trannys with 4.4 are all the same.. the 98 and up spec jdm type r tranny have the 4.7 and a longer (gsr, 3rd 4th and 5th) everything else is the same.
us itr tranny with 4.9 you will be fine with the hp you got. 24.5-25s with that range of hp you mentioned.
mx621
Dec 16, 2006 12:45 PM
JDM_Risa
Jan 17, 2006 10:09 PM
StinkyTofu
Aug 17, 2003 05:46 AM
nY's FiNeSt
16
Jan 7, 2003 01:52 PM
99Civic hatch
Jun 28, 2002 05:47 AM
