how to remove 90-91 door panels?
Old May 20, 2004 | 08:26 PM
Civic138's Avatar
Default how to remove 90-91 door panels?
well i already know how to take them off,but how do i get around the seatbelt that goes into the panels?(i just cut the seatbelt to get the ones off at the junkyard) and need to get these put on.
Old May 20, 2004 | 08:40 PM
rhetorical's Avatar
i believe at the bottom there is a swinging plastic piece that has a screw, and then at the top... you have to unscrew the metal plate from the door panel, then the plastic piece should come free.
Old May 20, 2004 | 10:21 PM
stealth civic's Avatar
Default Re: (rhetorical)
At the top there are plastic screws inside of the molding Standing on the inside of the door, push the lower window molding away from you exposing the screw. The pull out the plastic peice that holds the belt in place on the upper part of the door. Now all you have to do is slide out the belt and you are done.
Old May 21, 2004 | 08:38 AM
Civic138's Avatar
Default Re: (stealth civic)
thanks for the help everyone
alex1321
12
Jan 25, 2013 08:59 PM
96teggynonVtec
Feb 18, 2006 02:22 PM
ThaSpitefulWun
Nov 7, 2003 05:55 AM
teg95
May 22, 2002 01:16 PM
onyx00
Sep 5, 2001 12:44 PM
