CP Pistons 84mm 12.5 compression with b20block and vtec head??? (stock shelf pistons question)
Old May 20, 2004 | 07:44 PM
rodimus's Avatar
Default CP Pistons 84mm 12.5 compression with b20block and vtec head??? (stock shelf pistons question)
http://www.cppistons.com/PDF%20Files/CPImport.pdf
which head are they referring to when they say vtec head?
i know that advertised compression is often different then the true piston compression..how about these?
Old May 20, 2004 | 08:11 PM
Rocket's Avatar
Default Re: CP Pistons 84mm 12.5 compression with b20block and vtec head??? (EVOL)
That would be B16 at 42.7cc.
Let me know if you need help with other CP specs as I have specs not listed on their site.
Old May 20, 2004 | 08:19 PM
Rocket's Avatar
Default Re: CP Pistons 84mm 12.5 compression with b20block and vtec head??? (Rocket)
CP sizes the dome according to bore size so that 84.0mm 84.5mm, 85.0mm pistons have the same CR because as the bore increase the dome needs to be a little smaller.
You can thank Darius of CP for this attention to detail.
Old May 20, 2004 | 08:28 PM
rodimus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">CP sizes the dome according to bore size so that 84.0mm 84.5mm, 85.0mm pistons have the same CR because as the bore increase the dome needs to be a little smaller.
You can thank Darius of CP for this attention to detail.</TD></TR></TABLE>
take note everyone- rocket = good info
thanks robert... that compression question just came up because i've seen wiseco pistons and toda pistons advertised/claimed compression higher than what the compression actually was..and i'm pretty much set on CP pistons so thats why i asked about them.
edit: although 12.5 would be too high for my application IMO
Old May 20, 2004 | 10:45 PM
KoRE's Avatar
they assume a 0 piston to deck height though... at least that is what i was told by darius
darius
rocket
90CB7EX
K Series
Nov 16, 2016 07:20 PM
devious_yeti
May 2, 2016 07:30 PM
kevin7200
Jan 12, 2015 08:18 PM
b0yg0tskills
Honda Civic (2001 - 2005)
11
Feb 3, 2007 03:11 PM
KoRE
Nov 24, 2003 07:18 PM
