b16 swap. using teg spindles...what UCA? how?
Old May 20, 2004 | 07:06 PM
coot_er's Avatar
Default b16 swap. using teg spindles...what UCA? how?
im about to finish my b16 swap on my Hf and the only thing left is the front hubs. i have 91 integra spindles and the lower ball joint bolt is stripped. do i use the Hf UCA? how do i take out and put in the integra hub into the Hf spindle?
Old May 20, 2004 | 07:12 PM
deftones0817's Avatar
Default Re: b16 swap. using teg spindles...what UCA? how? (coot_er)
I believe that your hf spindles will work. think they are interchangable for 90-93 integra and 88-91 crx/civic
DEF
Old May 20, 2004 | 07:27 PM
coot_er's Avatar
Default Re: b16 swap. using teg spindles...what UCA? how? (deftones0817)
do i have to use the Hf spindles? if i use the Hf UCA how do i get the integra hubs out and put them into the Hf.
Old May 20, 2004 | 07:35 PM
cant use hf spindles with b16 swap. You use integra spindles with hf upper control arms. That will work fine
DEF
Old May 21, 2004 | 07:58 AM
coot_er's Avatar
do i have to take them to a shop to get the hubs pressed out of the UCA or is there a way i can do it myself?
Old May 21, 2004 | 08:24 AM
crx_88_si's Avatar
do u have a ball joint seperator (aka pickle fork?)
Old May 21, 2004 | 09:02 AM
coot_er's Avatar
Default Re: (crx_88_si)
ya
Old May 21, 2004 | 09:24 AM
coot_er's Avatar
Default Re: (coot_er)
its not that im trying to seperate the ball joint im trying to use the CRX UCA with the integra splines. i don't know how to get them out of the integra UCA and put them into the CRX UCA.
EF8IGHT
Aug 30, 2005 01:58 PM
crx50
Apr 14, 2004 11:02 AM
lordhuh
Jul 24, 2002 08:01 AM
