arias pistons, 9.0:1 can't tell intake and exhaust side help
Old May 20, 2004 | 06:07 PM
12thstreetjunkman's Avatar
Default arias pistons, 9.0:1 can't tell intake and exhaust side help
I am putting my shortblock together, I can't tell which is which. The valve releifs look the same to me, I think I remember on my last set, that the arias stamp on the bottom goes on the exhaust side of the wrist pin but I can't remember. If someone knows kit me up.
Old May 20, 2004 | 06:17 PM
99B16Si's Avatar
im assuming theyre not vtec pistons...correct?
Old May 20, 2004 | 06:20 PM
Default Re: (99B16Si)
well, they are going in a 2.0ltr gsr, so the will be in a vtec motor, but I don't think that has anything to do with it. the pistons will work with either stroke.
Old May 20, 2004 | 07:56 PM
Default Re: (12thstreetjunkman)
the side opposite to the arias stamp does look like the valve relief is closer to the edge being a little bigger, but it would be nice If someone else
has some input just to be on the safe side
Old May 20, 2004 | 08:00 PM
99B16Si's Avatar
the intake side has the side with the larger valve reliefs
Old May 20, 2004 | 08:02 PM
I know the intake valves are bigger, my problem is the top of the piston is a big bowl, and I can't tell what side is bigger, with higher comp pistons it is easy where the dome is cut into. The valve reliefs are all but cut out because of the dish on these making both sides look the same to me .
Old Apr 30, 2006 | 12:37 PM
Shmaa's Avatar
Default Re: arias pistons, 9.0:1 can't tell intake and exhaust side help (12thstreetjunkman)
So which is which?
Old Apr 30, 2006 | 12:44 PM
alpha's Avatar
Post a picture of the pistons and we will tell you.
Old Apr 30, 2006 | 01:41 PM
Shmaa's Avatar
Default Re: arias pistons, 9.0:1 can't tell intake and exhaust side help (0x64)
At first I was assuming the relief that came closer the the edge was the intake valve, but the other side actually looks a tiny bit deeper and I'm not putting the other spiral lock in until I know for sure.
Modified by Shmaa at 9:47 PM 5/1/2006
Old Apr 30, 2006 | 01:48 PM
shortyz21's Avatar
Default Re: arias pistons, 9.0:1 can't tell intake and exhaust side help (Shmaa)
left side looks bigger to me..
use a micrometer.. its close
Old Apr 30, 2006 | 01:57 PM
turboteg2nv's Avatar
Default Re: arias pistons, 9.0:1 can't tell intake and exhaust side help (shortyz21)
^^^ Exactly what I was thinking. Don't guess, MEASURE. micrometers are a nerd's best friend.
Old Apr 30, 2006 | 02:00 PM
Shmaa's Avatar
Default Re: arias pistons, 9.0:1 can't tell intake and exhaust side help (turboteg2nv)
This is why I am here usually at least someone on here knows for certain, but regardless I am wating to hear back from ARIAS.
Old Apr 30, 2006 | 02:12 PM
civicguy's Avatar
right side is your intake
Old Apr 30, 2006 | 02:20 PM
alpha's Avatar
Right side
Old Apr 30, 2006 | 02:54 PM
non-VTEC's Avatar
deffinatly the right side is the intake on that picture.
Shmaa's Avatar
Thats the way I have them set on the rods.
So this 100% I can put the spiral locks on sure?
Old Apr 30, 2006 | 04:18 PM
quicksilver1689's Avatar
i ♥ snails
The intake valves are larger than the exhaust correct? The right side seems to have more relief cut into it.
Old Apr 30, 2006 | 08:41 PM
earl's Avatar
Put a quarter on one relief and a quarter on the other relief. It will help you see the difference in sizing. Intake side will have more material removed around the quarter than the exhaust.
Old May 1, 2006 | 06:18 AM
blackhatchb20's Avatar
Default Re: arias pistons, 9.0:1 can't tell intake and exhaust side help (earl)
Look at the piston itself. look right at the bottom of the picture where the valve reliefs hit the side of the piston. Notice the right side is thinner than the left? Right side is your intake
Old May 1, 2006 | 12:22 PM
Shmaa's Avatar
Default Re: arias pistons, 9.0:1 can't tell intake and exhaust side help (blackhatchb20)
Just got an E-mail from Arias:
"The intake valve relieves are under "ARIAS", when you look in the
underside
of the pistons, the name ARIAS is engraved on the forging, the side
where
ARIAS is located will be the side with the intake valve relieves."
the ARIAS engraving is under the LEFT side of the piston in that picture....
Old May 1, 2006 | 12:55 PM
drintegra's Avatar
Good thing you calle daria, but the right side does look bigger
Old May 1, 2006 | 01:07 PM
Shmaa's Avatar
Default Re: arias pistons, 9.0:1 can't tell intake and exhaust side help (drintegra)
It's so close its rediculous, I did put a quater in the reliefs, but it was still so close it was hard to tell.
My original thought was the left side like I said in my earlier post. I even asked my girlfriend "which one of these cutouts look bigger. She picked the left side
Old May 1, 2006 | 04:16 PM
earl's Avatar
If you look closely at the edge of the piston, it looks like the reliefs are cut bigger on the right side of the pix. That would mean intake to the right.
That is how I would put it together, if I had to make that decision without any help.
Old May 1, 2006 | 04:46 PM
alpha's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">If you look closely at the edge of the piston, it looks like the reliefs are cut bigger on the right side of the pix. That would mean intake to the right.
That is how I would put it together, if I had to make that decision without any help.</TD></TR></TABLE>
+1
Maybe Arias made a mistake in their e-mail.
Old May 1, 2006 | 04:49 PM
Shmaa's Avatar
Haha this sucks, I sent another e-mail to ARIAS.
Nobody has assembled some 9:1 B18C ARIAS pistons WTH?
