99 ex w/99 Si swap....
Old May 20, 2004 | 05:56 PM
its WANG yoO's Avatar
Default 99 ex w/99 Si swap....
my buddy has a 99 ex with 99 si swap w/Gsr tranny. when the car is running...doesn't matter if its driving or sitting..the lights blink like cop lights....and his speedometer bounces everywhere....anyone had this problem before?
Old May 20, 2004 | 06:11 PM
BlownVR's Avatar
he should probably check alot of wires and ****. i know i have a wire loose in my engine bay and it was making spark and caused the whole dash lights to blink on and off. thats all i can think of right now is just to check for loose wires, if that dosent solve the problem then i guess he's screwed, good luck on finding the prob tho..
Old May 20, 2004 | 06:24 PM
chad's Avatar
Moderator
Default Re: 99 ex w/99 Si swap.... (SwapWhore101)
LOOSE GROUND!!!!!!!!!!!!
Turbogixxer's Avatar
Default Re: (CivicVXHatch)
Check your:
Grounds
Alt.
Old May 20, 2004 | 06:30 PM
98k20ex's Avatar
if not the alternator, it might have something to do with the ecu. what kind of wiring harness and ecu is he using? one of my friends did that same swap and made his own wiring harness and had electrical problems.
Old May 20, 2004 | 07:25 PM
743's Avatar
743
Default Re: 99 ex w/99 Si swap.... (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">LOOSE GROUND!!!!!!!!!!!!</TD></TR></TABLE>
Old May 21, 2004 | 04:31 AM
Default Re: 99 ex w/99 Si swap.... (x-743-x)
he's using P2T ecu(99-00 Si)...
i'll check all the grounds...thanks guys!
KidDxbOrI
Oct 29, 2014 04:54 PM
tysonboy
13
Oct 15, 2009 03:19 PM
its WANG yoO
Jun 11, 2007 02:54 PM
blackie
Feb 14, 2006 06:54 PM
HybridGSR
Jan 11, 2002 02:44 PM
