so i hooked up the vtec...
Old May 20, 2004 | 05:32 PM
labatia's Avatar
Default so i hooked up the vtec...
specs: 95 civic
motor jdm d15b
ecu jdm p08 ecu vtec
so i run the wire from the vtec solenoid to the a4 of the ecu harness
then i ran the wire to d6 of the ecu which was the vtec sensor?
i spliced the old sensor wires which was green and spliced the d6 wire to it.. and the black wire i left alone
i have another wire which is blue and black from the harness that came with the motor... should i use that and hook up the blue to the harness and the green to that harness too?
vtec kicks in the engine light is still on
did i do it right?
do i have to put them into the harness up there?
Modified by labatia at 2:43 AM 5/21/2004
Modified by labatia at 2:45 AM 5/21/2004
Old May 20, 2004 | 05:38 PM
Shaun's Avatar
whats the code its throwing
Old May 20, 2004 | 05:43 PM
labatia's Avatar
Default Re: (Shaun)
i havent checked it
it got dark outside im pretti sure its the sensor for vtec
Old May 20, 2004 | 05:46 PM
Tad's Avatar
Tad
well check it,
who knows what it is.
it could EAAAASILY be something other than the vtec solonoid
Old May 20, 2004 | 05:48 PM
labatia's Avatar
Default Re: (Tad)
well tad the thing is i didnt hook it up like the picture up there...
Old May 20, 2004 | 06:37 PM
jdmsiR20's Avatar
Default Re: (labatia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by labatia &raquo;</TD></TR><TR><TD CLASS="quote">well tad the thing is i didnt hook it up like the picture up there...</TD></TR></TABLE>
no matter, check the code first, its gonna tell you whats going on...
projecthonda
Feb 23, 2007 06:48 PM
GreddyCivic7
Feb 10, 2007 03:35 PM
sammydigital
Jun 9, 2006 05:31 PM
lilbluehatch
12
Apr 16, 2005 05:43 PM
lightningd
Apr 4, 2003 01:30 PM
