those experienced with alignment racks
Old May 20, 2004 | 03:28 PM
hellas's Avatar
Default those experienced with alignment racks
lets say you do an alignment with worn (but evenly worn) tires
then you put brand new tires on, the same size as before, then throw it on the rack again. will any alignment numbers change?
thanks
if you want to read some more:
im getting an inner shoulder wear problem on my FL corner with (properly selected)oversize tires. only thing is, the alingments ive had done were always done on my factory tires. my last alingment was done 8K ago, and only showed bad caster, which doest affect tire wear. im hoping going to the factory size will solve my probs
Old May 20, 2004 | 06:39 PM
doublejz's Avatar
Default Re: those experienced with alignment racks (hellas)
the alignment shouldn't change, they usually do the alignment with the wheels not the tires.
Old May 20, 2004 | 09:42 PM
hellas's Avatar
would changing tire size, but not wheel size affect alignment? specifically toe
Old May 21, 2004 | 05:08 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hellas &raquo;</TD></TR><TR><TD CLASS="quote">would changing tire size, but not wheel size affect alignment? specifically toe</TD></TR></TABLE>NO.
Old May 21, 2004 | 07:27 AM
Ekasey's Avatar
Default Re: those experienced with alignment racks (JimBlake)
it shouldnt but i have seen it before just remember set the toe first oh wait hondas only have toe muahahhahahha. You might wanna start looking for somehting that could be bent if your caster is out specs.
crxaddikt
12
Feb 6, 2011 05:28 PM
MILANO_RED_CL9
Acura TSX
Nov 24, 2010 10:11 AM
Rick hybrid
Dec 9, 2007 11:35 PM
darchon
Jan 26, 2006 02:18 PM
shadowz64
Aug 15, 2005 04:17 AM
