Motor brackets for B16 swap into EG??
NOt having all the of the mount I have heard can cause axles to break pre-maturely. Not having all the mounts has stopped me from completing my swap. Just my .02 cents
you dont need 1 and 5 but its much better to have them. if you choose to not run them for some reason spend the couple bucks and buy prothane inserts for the other three. with the inserts you won't even know you are missing them. i ran my swap for about 1-2 months with only 3 mounts and no inserts and the engine was torqing pretty bad. then i ran for about another 4 months with inserts untill i found the parts i needed for the front 2. I then installed the fronts with energy suspension inserts and couldn't tell they were there. it does make you feel much better though. by the way with 5 inserts your car will vibrate/rattle pretty bad.
wow... how do u guys run without torque mounts?? i put es inserts in mine about a month ago, and now my wheel hop is almost non-existant. i couldnt imagine how bad it would be with out anything there at all..... unless you replaced the rest of the mounts with solid ones
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN »</TD></TR><TR><TD CLASS="quote">Do I really need this bracket #5 for the b16 swap into EG??
haha i made this pic.
these are my mounts/brackets that i got for my jdm b16a gen2. I think it's a good idea to have all of them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">wow... how do u guys run without torque mounts?? i put es inserts in mine about a month ago, and now my wheel hop is almost non-existant. i couldnt imagine how bad it would be with out anything there at all..... unless you replaced the rest of the mounts with solid ones</TD></TR></TABLE>
I agree... I'm not sure how the engine would feel in your car without #1 and #5, #1 being the A/C bracket and #5 bolts to the tranny.
I would imagine you'd feel the engine rocking around in the bay while driving around
Save yourself that uneasy feeling and get all of them.
So the #4 mount is the correct mount for the tranny side for a b16 into an EG? I'm just double checking because my swap is sitting lower on the tranny side.
Is #4 the right one to use for an EG? Thanks in advance.
silvei2 eg6
Sep 14, 2004 10:12 AM
