automatic transmission question
Old May 20, 2004 | 01:44 PM
litterbox's Avatar
I am a (Trial User) Army
Default automatic transmission question
hey this is for my friend,
eg coupe. automatic transmission. when accelerating normally the transmission might get stuck at like 4000rpms or so. if you continue to lightly give it gas it will fall back into gear. sometimes it won't. sometimes you have to pull over, put it in park and then it goes back to normal. any suggestions? thx
Old May 20, 2004 | 04:56 PM
litterbox's Avatar
Default Re: automatic transmission question (litterbox)
cmon guys
litterbox's Avatar
someone must know
Old May 20, 2004 | 04:59 PM
RCautoworks's Avatar
Hows the fluid leval ? Does it get stuck in any gear at 4,000 rpms and does it have all the gears still, meaning does it skip 2nd or so on.
Old May 20, 2004 | 05:05 PM
litterbox's Avatar
Default Re: automatic transmission question (90blackcrx)
i believe all the gears are still there. if they aren't is that because the torque converter has gone bad or is it because the tranny's finished?
if all the gears are still there what should i tell my friend?
Old May 20, 2004 | 05:13 PM
Do all stall test to test the converter out, put it in 1 and hold the brake, press the gas a little and see if the car moves do it in 2nd gear to, do not hold the brake and gas down for more then 5 seconds. Check the fluid to, it sounds more like a hydraulic problem.
Old May 20, 2004 | 08:45 PM
litterbox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Do all stall test to test the converter out, put it in 1 and hold the brake, press the gas a little and see if the car moves do it in 2nd gear to, do not hold the brake and gas down for more then 5 seconds. Check the fluid to, it sounds more like a hydraulic problem.</TD></TR></TABLE>
so if the car moves right after you release the brake in 2nd it means that the torque converter is good right?
Old May 20, 2004 | 09:04 PM
Donkey85's Avatar
i would suggest changing the tranny fluid if it hasent been done in a while to see if it may help ur problem
Old May 21, 2004 | 07:53 AM
litterbox's Avatar
Default Re: automatic transmission question (Donkey85)
so i'm gonna do the stall test today at lunch time. if the torque converter is fine then how can i tell what is bad?
Old May 21, 2004 | 09:58 AM
The car should not move when you are doing a stall test, if so the converter is bad.
isuboy
Apr 8, 2008 10:54 PM
EGkid
Jun 8, 2005 06:08 PM
looking451
May 23, 2004 09:15 AM
litterbox
May 22, 2004 09:20 PM
vti-R
Oct 8, 2001 06:55 AM
