What is the largest size intercooler a stock crx can fit? 90-91
Old May 20, 2004 | 11:32 AM
ExplicitSpeed's Avatar
Default What is the largest size intercooler a stock crx can fit? 90-91
Just curious to what is the largest intercooler you may fit behind a stock 90-91 crx bumper. I am thinking 9" tall 33+ length including fins? and 3" thick. Plenty I would think to support 450+hp.
Old May 20, 2004 | 12:29 PM
rhetorical's Avatar
What else do you have to be puttin out 450+hp? What set up do you have/are you puttin together?
Old Jan 24, 2005 | 11:45 AM
1RMDave's Avatar
Default Re: (rhetorical)
I'm picking up one that is 25x11.25x3 I hope it fits.... i know i'll have to hack my bumper/support to ****.
Old Jan 24, 2005 | 11:50 AM
mrspeaker's Avatar
Default Re: (1RMDave)
6x3x28 and good for up to 400hp..It looks like a good fit for the front ..A little long but you can make it fit
And its forsale right now for $300 brand new..
https://honda-tech.com/zerothread?id=1124476
Old Jan 24, 2005 | 02:42 PM
alecjoesph's Avatar
Default Re: (Mrspeaker)
i had the standard drag fmic on my crx and it was hella trying to get it to fit...
Old Jan 24, 2005 | 03:27 PM
kyle h.'s Avatar
Default Re: (alecjoesph)
someone needs to come out with a stock,extended bumper for FMICs.
Old Jan 24, 2005 | 03:28 PM
Rostr02's Avatar
Default Re: (kyle h.)
<----------------------- Someone needs to get a turbo
Old Jan 24, 2005 | 03:58 PM
ZhaGg's Avatar
Default Re: (Rostr02)
this is what I've got:
it's a Trust intercooler I found in a dumpster in Japan. It sorta depends on what you mean by "fit"...
Old Jan 24, 2005 | 04:28 PM
hatchinprogress's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rostr02 &raquo;</TD></TR><TR><TD CLASS="quote">&lt;----------------------- Someone needs to get a turbo </TD></TR></TABLE> its the best thing i ever did to my ef.....but i still need an intercooler (right now it's just pipe(but its still quick)
Old Jan 24, 2005 | 05:08 PM
speeddave's Avatar
Default Re: (ZhaGg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZhaGg &raquo;</TD></TR><TR><TD CLASS="quote">this is what I've got
it's a Trust intercooler I found in a dumpster in Japan. It sorta depends on what you mean by "fit"...</TD></TR></TABLE>
what are the dimensions of that intercooler.... 24" x 12"??
Old Jan 24, 2005 | 05:12 PM
speeddave's Avatar
Default Re: (ZhaGg)
one thing to watch for in the ef cars is with a long intercooler 30+ inches, the charge pipes at the ends become a pita. you need a couple inches of straight on each end past the cooler ends, so that the bend isnt in the silicone coupler. this makes the 90deg turn you have to make off the cooler really tight.
Old Jan 25, 2005 | 03:24 PM
ZhaGg's Avatar
Default Re: (speeddave)
I can't remember the dimensions... I posted it a long time ago on the FI forum.
The end pipes are sorta tough to deal with... The pain for me was making the facia fit with the 2.5" charge pipes. I had to bust out the drill saw and die grinder... I normally wouldn't use pipes that are so large, but the I/C inlet/outlet are 3"... It was a compromise of sizing.
You don't get to be choosy when you're trash-diggin'...
13g-crx
Feb 21, 2008 03:43 PM
wernhersey
Sep 13, 2007 10:26 AM
c0nspire
22
Jun 24, 2004 01:43 PM
2k2silvertype-s
Feb 25, 2003 05:27 PM
paulzy
Sep 26, 2001 06:35 PM
