First post on HT!!!!!!!!!!! Need some help with my ITR =)
Old May 20, 2004 | 11:27 AM
thelobster's Avatar
Default First post on HT!!!!!!!!!!! Need some help with my ITR =)
I have a 2000 Itr with Jun Header, Comptech icebox (full intake and icebox), and a A teo cat (from a long time ago, I read it was a good cat from H-T). Well my ITR fail Smog today, the sniffer said I was a gross pollutor. WHY? I still have a cat and a header and intake is not going to change things, is it? Also the computer said I fail in the timming part too (I just did my 36k miles service and the acura dealer should of checked that). Any ideals about what I should do? A buddy of mines said he can get someone to do it for $150 but I dont want to be a gross polluter.
Old May 20, 2004 | 11:36 AM
JDM CTR '00's Avatar
Default Re: First post on HT!!!!!!!!!!! Need some help with my ITR =) (thelobster)
Put all the stock parts back on and fix ur timming. Then try again
Old May 20, 2004 | 11:47 AM
Bbasso's Avatar
Do you have any CELs?
Old May 20, 2004 | 11:55 AM
thelobster's Avatar
Default Re: First post on HT!!!!!!!!!!! Need some help with my ITR =) (Bbasso)
NO CEL's never had a problem with anything.
Old May 20, 2004 | 11:59 AM
.brad's Avatar
25 Year Member
If you've still got your OEM cat put it back on and run it through.
I've heard aftermarket cats quickly go bad.
Old May 20, 2004 | 12:07 PM
thelobster's Avatar
Default Re: First post on HT!!!!!!!!!!! Need some help with my ITR =) (.brad)
My OEM cat has been sitting in my garage for 3 years, do you still think it works?
Old May 20, 2004 | 12:08 PM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thelobster &raquo;</TD></TR><TR><TD CLASS="quote">NO CEL's never had a problem with anything.</TD></TR></TABLE>
How about what state or province or country you are trying to pass emissions in? I'm guessing Ca. with the reference to Smog and all.
Then, do you have any of the stock stuff to put back on?
Then, is this the first time you are trying to pass emissions?
Did you buy this car like this? Or did you do the work/ mods?
Teo cat? Never heard of it, Carsound passes in many places no problem.
Old May 20, 2004 | 12:58 PM
CW-ITR's Avatar
Here is my suggestion. Retard timing by 2-3 degree and put the OEM cat back on. Good luck.
thelobster's Avatar
Default Re: First post on HT!!!!!!!!!!! Need some help with my ITR =) (1GreyTeg)
California
no stock stuff
YEs, my first smog check
Car was bought new, I did the work my self
It is a carsound cat 54XXX something like that (modified by A. Teo sorrry for the confusion)
Im thinking of just doing it the illegal way, i dont want to cause its so expensive but i might have to. Anyone with a good place to do it at in Orange county california? Email mle3@sbcglobal.net
Old May 20, 2004 | 02:36 PM
George Knighton's Avatar
H-T Order of Merit
Default Re: (CW-ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW-ITR &raquo;</TD></TR><TR><TD CLASS="quote">Here is my suggestion. Retard timing by 2-3 degree and put the OEM cat back on. Good luck.</TD></TR></TABLE>
This makes sense.
I'd try that, and if that doesn't work there are a hell of a lot of good ITR Honda Tech people in California who can lend detailed assistance.
Old May 21, 2004 | 04:35 PM
thelobster's Avatar
Default Re: (George Knighton)
Hmmm.... how do I adjust the timming by myself? Anyone have any articles on timming advance/retard?
Old May 22, 2004 | 03:18 PM
thelobster's Avatar
Default Re: (thelobster)
If I fail once and my itr "exceeded the gross polluter limits" do I have to go to a test only center?
Old May 22, 2004 | 03:20 PM
zad5's Avatar
u mite just need to borrow a cat or maybe ur header is too hardcore for smog. post ur results.
Old May 22, 2004 | 03:24 PM
fuck honda-tech's Avatar
go to a place where the test u and if u dont pass u dont pay
Old May 22, 2004 | 04:02 PM
thelobster's Avatar
Default Re: (zad5)
can someone host my scan of the results?
Old May 22, 2004 | 04:49 PM
jiahanhao's Avatar
everything that you put in your car has to have the carb e.o numbers on the parts... you need to either buy new parts that are carb certified, or put the stock parts back on.. the a-teo cat won't pass, nor will the jdm jun header. You can do all this, or pay someone to pass you...
RGoose18
Feb 1, 2011 07:45 PM
Jxi8s2k
Dec 2, 2007 02:34 AM
Justin Klemgold
11
Mar 22, 2006 04:19 PM
vtec.com
Apr 18, 2004 04:49 PM
Chris N
Sep 18, 2002 06:48 PM
