NO SPARK
Old May 20, 2004 | 07:17 AM
scottcal's Avatar
Default NO SPARK
just put new head on double checked timing
marks they are lined up , go one little intermittent
spark and then nothing it wont fire got good compression
and fuel,wanted to know if there is something i am over-
looking
Old May 20, 2004 | 07:27 AM
b18cx's Avatar
Default Re: NO SPARK (scottcal)
I would first check the ground at the water neck. Of course check ALL your fuses. IF neither cure it, tyr swaping the distributor out with a friend to see if its gone bad.
If that does'nt do anything, sounds like a timing issue.
Old May 20, 2004 | 07:54 AM
scottcal's Avatar
Default Re: NO SPARK (b18cx)
that sounds like that might be it
because i dont remember putting
a ground on the housing ill
give it a try tonight thanks.
Old May 20, 2004 | 12:33 PM
Jimmy's Avatar
Global Moderator
check that ground then check out the dizzy.
Old May 20, 2004 | 02:25 PM
scottcal's Avatar
Default Re: (Jimmy)
what is the dizzy
Old May 24, 2004 | 12:23 PM
scottcal's Avatar
the ground fixed the problem thank you.
96Formula6spd
Mar 4, 2011 08:58 PM
tree fingers
Aug 5, 2009 07:09 AM
90Rexx
Jul 3, 2009 06:23 AM
jason007
Apr 1, 2008 04:12 AM
Dan in Japan
Jul 28, 2005 06:23 PM
