which HONDATA for my set up?
Old May 20, 2004 | 04:35 AM
SupaFly_Honda's Avatar
Default which HONDATA for my set up?
heres my setup that I recently just got done with. Its pretty basic...
ls/vtec:
Pr3 head with full skunk stage2 vavle train and cam gears/ aebs manifold/ 64mm throttle body/ jdm dc header and 310rc injectors.
gsr block with mugen headgasket/ Ls rods/ Ls crank with arp rod bolts/ head studs and standard size jdm P30 pistons.
which hondata system will work best with my setup? S100 or 200? any other suggestion is welcome.
Old May 20, 2004 | 04:42 AM
jdmcx's Avatar
Default Re: which HONDATA for my set up? (SupaFly_Honda)
if you have the money go with the s200 but if you don't s100 will surfice
Old May 20, 2004 | 10:30 AM
andrewasf77's Avatar
Default Re: which HONDATA for my set up? (jdmcx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcx &raquo;</TD></TR><TR><TD CLASS="quote">if you have the money go with the s200 but if you don't s100 will surfice</TD></TR></TABLE>
isnt the s200 only like $40 more? i would go ahead and spend the few extra so you can options donw the road when you add more mods
00dc4
May 7, 2008 02:26 PM
arrojj
Feb 19, 2006 01:12 PM
BoOsTiN Dc2
Sep 29, 2005 09:23 PM
chinegro
Jan 30, 2005 07:16 PM
flyrice
13
Nov 27, 2003 10:10 PM
