SRS light..HELP EVERYONE!!!!
Old May 19, 2004 | 10:38 PM
niccuhles's Avatar
Default SRS light..HELP EVERYONE!!!!
so im stripping my 2000 HB out getting it ready for some stuff, and in order to take the carpet out with out cutting it, i have to unplug the SRS plug that sits behind my cup holders. after im all done i plug it back up. i go to start my car and the SRS light stays on, how do i make it go away!!!!!! ive heard unplug the ecu fuse, or take off both battery terminals. what else can i do?!
Old May 20, 2004 | 06:50 AM
taz77's Avatar
New User
Default Re: SRS light..HELP EVERYONE!!!! (niccuhles)
take it to a dealer to have it reset
Old May 20, 2004 | 07:35 AM
b18cx's Avatar
Default Re: SRS light..HELP EVERYONE!!!! (taz77)
Since your stripping you car for weight savings, I assume your going to pull the air bags at some point in time (LOTS OF WEIGHT) and use the JDM delete tray and possibily a aftermarket steering wheel.............
PULL THE BULB OUT OF THE CLUSTER. They will still work.
Old May 20, 2004 | 09:37 AM
Ekasey's Avatar
Default Re: SRS light..HELP EVERYONE!!!! (b18cx)
if your looking to get rid of the code light buy the factory dummy plugs (airbag simulators) honda uses for diag. testing or try wiring in a 2 ohm resistor
Type 56
Feb 11, 2019 08:53 PM
solslow
Mar 11, 2005 12:36 AM
niccuhles
May 19, 2004 10:46 PM
2point0VTEC
Aug 21, 2002 11:17 PM
