How do you reset SRS light on a 93 delsol?
I followed this link:
http://www.knology.net/~jediklc/srsreset.htm
I used a paper clip to plug into the yellow mes connecter, but the light won't come off like it said in the webpage after 6 secound with the igition switch to on.
*i've installed a momo corse steering wheel, but i guess u can still reset the srs light with an aftermarket steering wheel rit?
Any help will be great! Thanks!
Re: How do you reset SRS light on a 93 delsol? (dondon22)
You're going to need to trick the SRS computer into thinking that it still has an airbag on the driver's side. How you do this, I don't know for sure, but someone on here does. I wouldn't think it would be that difficult, a paperclip or resistor in the connector or something? Airbag stuff is a pain, and I wouldn't mess with it myself. Someone will tell you. When you do that, the light will probably go away by itself.
Re: How do you reset SRS light on a 93 delsol? (BlueIntegraBoy)
Good thinking Nick I forgot that the 93's only had the driver's airbag. You don't have an airbag anymore, so you don't need the srs module either. Disconnecting either of those plugs will get rid of that light.
