Acura NSX Honda / Acura NSX 1990 - 2005 || Honda / Acura NSX 2017 -
What are the main problems with NSX's?
Old May 19, 2004 | 10:14 PM
HondasHaveNoTorque's Avatar
Default What are the main problems with NSX's?
Looking to purchase one soon , so im just wondering any help will be greatle appreciated thanks
Old May 20, 2004 | 07:06 AM
NSX Bob's Avatar
New User
Default Re: What are the main problems with NSX's? (HondasHaveNoTorque)
You'll get better answers if you specify what years you are looking at. For example, the some 91's and 92's have a snap ring problem w/ the tranny that takes big $ to repair. What kind of $ you have to spend will dictate what years you could feasibly purchase, and based on that you could get a better answer.
Old May 20, 2004 | 09:12 AM
OC 335i's Avatar
Main problem for me is not enough money.
Old May 20, 2004 | 11:14 AM
Ponyboy's Avatar
Painting Masterpieces
https://honda-tech.com/zerothread?id=856655
Old May 20, 2004 | 09:25 PM
yea i was looking into a 91-92 , my bad, what do u mean by the snap rings sorry im into german cars usually , snap rings?
Old May 20, 2004 | 09:31 PM
ojas's Avatar
Default Re: (HondasHaveNoTorque)
Refer to the link Ponyboy posted. If you look under Troubleshooting > Transmission (inc. Snap Ring), you'll find this.
Old May 21, 2004 | 06:23 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (ojas)
IMO the most common problem with used NSXs is lack of scheduled maintenance. For example, there are lots of early NSXs on which the timing belt has never been replaced - specified by Acura for 90K miles or 6 years, whichever comes first, but still using a timing belt that is 12-13 years old.
The '91-92 "snap ring problem" is a susceptibility to the snap ring breaking, due to a mismanufactured transmission case. These cars are identifiable by transmission number. If it breaks and you recognize the symptoms (and don't keep driving on it), you can fix it for about $2K or so. You can also have a preventive repair for the same amount.
The '91-93 window regulators can fail, costing about $500 to replace (each side). This is preventable with the installation of a part costing $16.
Other common problems include trunk lid struts and engine hatch struts that wear out (inexpensive to replace, even less to repair) and stereo speaker/amps that go bad (inexpensive to repair, more expensive to replace). Most other problems are rare but can be pricey. Again, go through the FAQ for more information.
Toby Kraft
Audio / Security / Video
Oct 3, 2017 08:45 PM
AHHthatsJDMyo
Honda S2000
24
Oct 3, 2010 07:12 PM
fr3dy_1
Apr 7, 2008 09:16 PM
dailydriven91ex
Jul 25, 2004 04:00 AM
