Crx upper strut bar..which one is good ?
http://www.wiechers-sport.de/s....html
i only can give you this from germany.
but it has awsome quallity
Personally, I wouldn't bother blowing a large amount of cash for a strut tower brace. I would look on Ebay personally. They are cheap like $20 or cheaper. I have a neuspeed, had a tenzo r. and one that didn't come with a sticker (generic). They all serve the same purpose. That is unless you want some
bling.
bling.
I like Neuspeed, because it's all solid, rather than having bolts that can still flex/move/whatever...
I don't know if it really makes a difference being solid or not, but I got the Neuspeed strut bar for a stock airbox plus $25 so not too bad...
Alex
Alex
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skelly ed666 »</TD></TR><TR><TD CLASS="quote">Spoooooooon.... Or find a one piece bar if you can. EH/EJ/DC all fit the ED chassis. So you have alot of choices.</TD></TR></TABLE>
I coulda swore that the only other FRONT bars that fit 4th gen civics are from 2nd gen integras...EH/EJ/DC all mount different do they not?
or does this mean I can get one of those ebay mugen knock offs? i just like the design of them
rear ones are all the same though I know that
..i have the SpoonSports bar up front but no bar in the back yet..i will admit i got it for partial bling but..i would rather have a set of CARBING bars
I have an OMP one aswell, looks good and is a very stiff bar, but i found the finish pretty weak, and it rusted once it peeled off. Also, took me 45 minutes of fiddling/grinding to get it to fit on my DPFI, still rubs master cylinder and back of intake mani.
Guest
Posts: n/a
You can find the entire set of front rear and upper lower bar for pretty cheap on ebay for the price of a Neuspeed but the Neuspeeds are pretty nice for the money. Just crank down the adj. nuts on the ebay bars and you'll be good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CyniKal.Mindset »</TD></TR><TR><TD CLASS="quote">
rear ones are all the same though I know that</TD></TR></TABLE>
I have found w/ particular brands some fit and most others don't. With the front upper nuespeed it's the 88-91 civic and 90-93 integra...but with skunk2 the 88-00 civic BUT 94-01 integra fit. You just have to double check the part numbers and see the application lists....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TDRacing2 »</TD></TR><TR><TD CLASS="quote">I have an OMP one aswell, looks good and is a very stiff bar, but i found the finish pretty weak, and it rusted once it peeled off. Also, took me 45 minutes of fiddling/grinding to get it to fit on my DPFI, still rubs master cylinder and back of intake mani.</TD></TR></TABLE>
Perhaps you got the wrong one. Mine rubs NO-where. I take it off regularly to work on some things. No grinding or whatever required. Installs in a matter of minutes.
I agree on the finish. It's just steel. You have to be careful with it. I cleaned it up, and clearcoated the whole thing. Wich helped alot.
btw,... I have one in the rear too. Mounts to the shock, and not the chassis. Same good quality. A bitch to take off tho.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erikiksaz1 »</TD></TR><TR><TD CLASS="quote">What if you took an Ebay strut bar and welded all of it's joints? Wouldn't that make it relatively strong? </TD></TR></TABLE>
Kinda hard to weld aluminum to steel, maybe with a bronze rod... Anyways if you tighten them real good there shouldn't be any play in the joints.
