96 vtec F22b1 swap into a 90 accord NEED HELP!!!!
I swapped a 96 accord ex vtec engine into a 90 accord. I used my wiring harness from my 90 engine and everything fit fine. I am using my ecu from my 90 accord and I am also using my distributor from my 90 engine. When i start the engine it runs fine, but then when you are driving there is a knocking noise, coming from the engine and my RPM's cut off a 4500. When my car is idle there is NO knocking noise, the noise is only when i am driving. What is wrong? What is the knocking noise that i am hearing? Where is it coming from? Why are my RPM's cutting off at 4500? Please someone HELP ME!
is your 96 f22b1 vtec and OBD1 or OBD2.
if i am not mistaken, i think it may be an OBD2. i bought a 94 f22b1 and i know it is an OBD1.
2-- i think some of your problems may stem from the fact that u r running a vtec motor (which may be OBD2) off an ECU that is OBD1 and non-vtec.
3-- the RPM deal could be because your motor wants to engage into vtec, but it does not have the capability to do so...or do u have something to send a 12 volt signal to the vtec solenoid?..like a shiftlight, window switch, or something.
just my 2 cents...i could be wrong...if i am, can some1 fill us in
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by repherence1 »</TD></TR><TR><TD CLASS="quote">is your 96 f22b1 vtec and OBD1 or OBD2.
thanks</TD></TR></TABLE>
Sounds about right. You need to wire for vtec and change over to obd2 and if you haven't you need to change your ecu (someone correct me if I am wrong)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr »</TD></TR><TR><TD CLASS="quote">
that would be teh wise move!
</TD></TR></TABLE>that would be teh wise move!
DVSRMZ450
Dec 9, 2012 07:43 PM
90coupekami
Sep 23, 2012 11:22 AM
Davoucci_Pimp
Jul 27, 2004 11:51 AM
