91 crx Si seats in a 91 Std hatch?
Old May 19, 2004 | 08:20 PM
claytonsmith's Avatar
Default 91 crx Si seats in a 91 Std hatch?
well i stumbled on some mint crx Si seats... and from the best i can see.. theres really no way ( aside from fabricating seat rails) to make them bolt into mt hatch... i tried switching seat slider rail things....but the inner rails from the hatch seats wont fit the CRX seats.. and the outer rails from teh hatch seats are riveted to the seat pan...
anyone know of some way to put these CRX seats in my hatch?
thanks!!!
Old May 19, 2004 | 08:45 PM
Maddhatcher's Avatar
Default Re: 91 crx Si seats in a 91 Std hatch? (claytonsmith)
Im not sure how far off the holes are in your case, but when I installed del sol seats into my hatch I had to use 3/8 inch steel and make adapter plates to attach to the rails of the seat. It is pretty involved, however quite worth it in the end.
Best of luck to you.
I know there is a tutorial floating around on how to make the del sol seats fit, you may be able to adapt that method for your crx seats.
______LUKE
Old May 19, 2004 | 09:24 PM
thanks... ill look for that tutorial i guess
anyone else know anything??
thanks!
Old May 20, 2004 | 08:02 AM
anyone? bueller... bueller.... bueller...??
Old May 20, 2004 | 08:25 AM
manson's Avatar
Default Re: (claytonsmith)
:raises hand:
I Know! you can sell me those mint SI seats...and then with the $$$$ i give you, you can buy the SI Civic seats!!!
everyone is happy!
let me know.
Old May 20, 2004 | 08:46 AM
keithv's Avatar
Default Re: 91 crx Si seats in a 91 Std hatch? (Maddhatcher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maddhatcher &raquo;</TD></TR><TR><TD CLASS="quote">I know there is a tutorial floating around on how to make the del sol seats fit, you may be able to adapt that method for your crx seats.</TD></TR></TABLE>
Here is a tutorial on how to put the Del Sol seats into a 90+ Civic.
http://www.thedropshop.tv/seats.html
Old May 20, 2004 | 11:01 AM
tilt's Avatar
i dont know if it will work, but if you have both set of seats... have you tried swapping out the seat pans?
https://honda-tech.com/zerothread?id=347548
Old May 20, 2004 | 12:10 PM
b16_madman's Avatar
Default Re: 91 crx Si seats in a 91 Std hatch? (tilt)
I was lookin forward to the Corbeau. Man, dude, sorry I thought for sure these would fit. This coming from someone who has a 88 civic, had a crx seat at one time, but it sat crooked and now has 90 si seats.
Maybe we can get together to see if it's worth the hassle or not.
Old May 20, 2004 | 12:12 PM
b16_madman's Avatar
Default Re: 91 crx Si seats in a 91 Std hatch? (B16_madman)
that seat pan writeup would be worth a shot, but it would only be useful for your passenger seat, or do you have the std drivers seat?
Old May 20, 2004 | 08:35 PM
andy: nope i dont have the drivers seat
and "mansonteamsmyt" : what are you interested in paying for the the seats? .. theyre pretty much perfect.. the drivers side left bolster is SLIGHTLY soft.. but not worn/ ripped at all... frankly theyre the best seats ive seen.. i guess a skinny little dude or a girl had the crx..
anyway lemme know what youre willing to pay and where youre located... i'd rather not ship them to cali or something like that.
lemme know here.. or email me at rc_ofna@yahoo.com
thanks
-Clayton
Old May 20, 2004 | 09:01 PM
johnclaunch's Avatar
I need some blue DX or vinyl seats in perfect shape!!!! hehehe
Old May 20, 2004 | 09:13 PM
b18cEF9's Avatar
Default Re: 91 crx Si seats in a 91 Std hatch? (johnclaunch)
i got some nice **** 89 si seats for the hatch if u wanna buy them, let me know
Old May 20, 2004 | 09:39 PM
thanks but ill hold off for now.. i found an si hatch that im trying to save for so all $ i have / get is gonna be applied towards that.
Old May 20, 2004 | 09:48 PM
Rene M's Avatar
From doing some swapping my self i found this out my self... But, 88 crx/Civic seats have the non door mounted seat belts and if you take the foam and covers off the 90-91 seats and mount them on the 88 seat pans they will just bolt in....
I had to do the reverse in my wifes car... 88 si seats in a 90... Its a time crunch deal but real easy... All you need is a set of hog ring pliers...
Old May 21, 2004 | 05:52 AM
^Sammy]!.'s Avatar
From: 9/11/01 WTC Never Forget, United States Of America
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by claytonsmith &raquo;</TD></TR><TR><TD CLASS="quote">well i stumbled on some mint crx Si seats... and from the best i can see.. theres really no way ( aside from fabricating seat rails) to make them bolt into mt hatch... i tried switching seat slider rail things....but the inner rails from the hatch seats wont fit the CRX seats.. and the outer rails from teh hatch seats are riveted to the seat pan...
thanks!!!</TD></TR></TABLE>
I followed what EF_LSVtec did when I did my ITR seats into my EF hatch
Check the link:
https://honda-tech.com/zerothread?id=289354
Old May 21, 2004 | 06:49 AM
b16_madman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by claytonsmith &raquo;</TD></TR><TR><TD CLASS="quote">thanks but ill hold off for now.. i found an si hatch that im trying to save for so all $ i have / get is gonna be applied towards that.</TD></TR></TABLE>
If you can't get it man, I might.
Dang I wish I had known back in the day to switch my seat pans from my 88 dx seats to fit on my 90 si seats. I have it ghetto rigged. Inner rails bolt up (prolly from my 88dx seats can't member) and outer rail from the 90 si. Front mounting hole goes thru the floor with a nice thick steel backing plate about 3" square (1/4" thick or so) and rear mounting hole has a "L" bracket, then two bolts for each rearward mounting hole thru the floor.
It looks ghetto with the three bolts thru the floor for each side, but it's fun to skid them on speedbumps.
Here you can see the rear two sticking out from the underside
Old May 21, 2004 | 09:34 AM
Rene M's Avatar
Default Re: (B16_madman)
thats funny..... the art of back yard.... uh, art?
Old May 21, 2004 | 10:01 PM
you better back off my kool-aide andy!!! hands off the hatch! it was my idea!!!!!! lol
Old May 25, 2004 | 07:08 AM
stangyaracing's Avatar
Hey I need those CRX Si seats you can e-mail me at gorum2@***.net do you have any pics? and how much will you sell them for? Thanks, John.
Old Jun 1, 2004 | 02:02 AM
crxkane's Avatar
how much you looking to get for them. pm me and let me know... thanks
Old Jun 1, 2004 | 04:06 AM
SamuelK's Avatar
i once had the same problem as you, it sucked! I had to sell the seats back to the guy. But i have a new pair of Si seats now, PM me if interested, they are near perfect
KOOCHYOLOGIST
Jan 2, 2010 03:20 PM
ATL-EF squad
Aug 11, 2008 08:35 AM
square_1
Jun 17, 2007 05:15 AM
kevinm1981
Sep 23, 2003 05:41 PM
Ham'ed Hatch
11
Oct 8, 2002 04:34 PM
